OBD1 to OBD2a
Old Nov 29, 2010 | 06:47 PM
nothing_shocking's Avatar
Default OBD1 to OBD2a
Does anyone know where I can get a jumper to hook an OBD1 wiring harness up to an OBD2a ecu? I've been searching and all I can find are OBD2 to OBD1 jumper harnesses...
I'm putting a B18B1 into a 92 civic si and I'm wanting to use the stock shock tower harness.
Old Nov 29, 2010 | 07:21 PM
mtber's Avatar
Default Re: OBD1 to OBD2a
We sell the harness you are looking for on our website.
I recommend you get your self an obd1 p75 ecu or a chipped obd1 non-vtec ecu.
It will cost less then the obd1 harness to obd2a ecu jumper you are trying to buy.
Old Nov 29, 2010 | 09:23 PM
HAMOTORSPORTS's Avatar
Originally Posted by mtber
Get your self an obd1 p75 ecu or a chipped obd1 non-vtec ecu.
^ Best advice - use an obd1 ECU. If you don't want to go that route, we can have one made for you for a reasonable price, just PM me. But beware using an OBD2 ECU you are going to have problems with check engine light for no second o2, CKF, evap, etc..
Old Nov 30, 2010 | 10:32 AM
I didn't realize that an obd1 ecu would work fine with an obd2 engine... If that's the case, my job just got cake, lol.
Old Nov 30, 2010 | 10:53 AM
mtber's Avatar
Yes, it will work perfectly fine :-)
Old Nov 30, 2010 | 11:28 PM
harms_is_back's Avatar
ok sorry to thread jack but i have a lsv motor that is obd2 with a obd2 harness with a obd2 to obd1 jumper with a chiped p28 and i have a check engine light with i dont know how to read because a scan tool doesnt work and i cant find the little jumper to make the cel blink help!
Old Dec 1, 2010 | 04:00 PM
mtber's Avatar
Read http://www.phearable.net/tech/
"How to check your MIL codes (Check Engine Light): "
JdM_Eg6_SiiR
Engine Management and Tuning
Dec 6, 2010 07:12 AM
rwlangdale
Jan 3, 2008 07:48 AM
hoskos
Oct 13, 2006 01:45 AM
boost fed ls
Aug 6, 2004 05:06 AM
Type RS
Nov 18, 2002 10:09 PM
