Need help understanding what I need
Old Oct 19, 2025 | 05:34 PM
ok_raul's Avatar
Default Need help understanding what I need
I have a high compression D16y8 with a ratio of 11:38:1i have headers exhaust cold air with a ported throttle body and after market intake manifold. I wanna know if I should I put a cam in it thinking of stage 2 and what do else do I need to get to get it working.
Old Oct 19, 2025 | 08:47 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Need help understanding what I need
Higher rate valve springs and retainers as well as some type of tunable engine management system.
Old Nov 23, 2025 | 09:31 AM
K7-1Ktrevor's Avatar
Loved
Community Favorite
The cam will make that motor come alive. You’ll need valve springs and a tune. I’d say stage 2 or 3 would both work depending on manufacture and specs of the cam. Stock injectors will be plenty, port work would be a bonus also but if your gonna go that route I’d get a z6 head, they flow better stock vs stock and have a much better port design over the y8’s wonky swirl port.
ESFCivic
Honda Civic (2001 - 2005)
May 23, 2013 01:36 PM
ekphil
Sep 21, 2010 01:50 PM
artin01
Sep 9, 2008 01:25 PM
willyboyK20
Mar 6, 2002 12:09 PM
