need base map for s300
i have an s300 and 1000 cc injectors i need a base map to get the car started so i can drive it to get tuned my set up is b16 bored to a 2.1 , 9.1:1 comp, with a full race ram horn manifold , sc -61 turbo and hondata 4 bar map sensor if someone can send me a base map it would be great thanks
i am actually going to leave it here, because it is against the rules in the engine management subforum to ask for a base map.
although not really tech related, there isnt anything here that says we cant have a thread like this.
hondata does have a subforum where you can put a post about a base map needed.
whats your email I will set up a map that should at least start it. I have a map that maybe close. I am not taking any responsibility for anything you mess up. It will be either later tues or wed when i can get it done cause im at work right now.
just attach it to an email, you attach it like you would a picture except you go to the smanager file ( which is most likely on your desktop ) and select whichever map your trying to attach. i have emailed my maps to a buddy to check a couple times.
The guy i want to get it dyno at is about 1 hr. from where i live i just need to get the car started to get there. When i put the stock injectors on and wire everything back up to stock the car runs fine , i just want to get the car running with the 1000cc and how its wired up now with the resistor box.
sewokozak
Engine Management and Tuning
Aug 9, 2018 02:08 PM
