LS/VTEC basemap
Old May 27, 2011 | 11:38 AM
alperx's Avatar
Default LS/VTEC basemap
Hi
I have a b18a1 + b18c1 fitted with 9:1 pistons, with obd1 distributor and Neptune RTP.
Is the standard P72 basemap good for the car for the break-in period ?
Should I check some stuff ?
Thanks.
Old May 27, 2011 | 06:22 PM
mtber's Avatar
Default Re: LS/VTEC basemap
If you are using a stock set of injectors & you have a wideband oxygen sensor to monitor everything, you should be good to go.
mapa1229
Jan 22, 2011 04:58 PM
carlossolorzano
Sep 4, 2010 06:24 PM
crxmex
Nov 15, 2006 07:18 PM
VNTEC
May 24, 2004 01:58 PM
