installtion M&W PRO10 ignition
Old Jan 27, 2012 | 06:31 AM
blown_mb2's Avatar
Default installtion M&W PRO10 ignition
Hi guys,
i have bought a M&W PRO10 + T1 race developement wire kit.
I have some question for the installation.
Wireing:
- big red - goes directly to battery (+12V)
- big black - goes directly to battery (GND)
is it necessary to go direct to the battery or can i connect to the fusebox inside the car. because my battery is far away in the trunk.
- small blue - is the speed signal for the cluster
should i run this wire in the OEM distributor. cut the old speed signal and solder it with the blue from the M&W
- small black - goes inside the car to ecu on ICM
- small white - switced +12V
INSIDE THE DISTRIBUTOR:
I have to remove the old coil and isulate the no necessary wires?
Thanks for the help when it possible is with pictures.
Tobias from germany.
with this 2 wires i go directly on the connector of the ECU
Old Jan 29, 2012 | 11:20 AM
xenocron's Avatar
Default Re: installtion M&W PRO10 ignition
http://t1racedevelopment.com/images/...structions.doc
TylerC161
Oct 24, 2018 06:43 PM
ohsnapzafingcu
Jan 1, 2009 10:06 PM
scrooge
Oct 9, 2007 04:35 PM
hb_guy
Apr 9, 2006 06:43 PM
microbreak
Feb 23, 2004 10:24 PM
