How to advance timing without tune
Old Jul 8, 2024 | 01:50 AM
Bangbucket's Avatar
Default How to mechanically advance timing no tune
I've got a 97 accord OBD2 auto trans I/H/E
The PCM controls timing. The bolt holes on the dizzy are not slotted.
Can I take a Dremel to the holes and make them slotted so I can turn the dizzy? Will that work?
If not, can I just stick an adjustable cam gear on it?
Old Jul 8, 2024 | 08:57 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: How to advance timing without tune
Those two adjustments will do VERY different things. What are you trying to accomplish ?
Old Jul 9, 2024 | 07:54 AM
Bangbucket's Avatar
I want to bump.up the ignition timing a bit for a few extra horses
Old Jul 9, 2024 | 09:09 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Then you slot the holes in the distributor.
ShBoxAccord
Mar 4, 2021 03:13 PM
integrx
May 12, 2004 02:48 PM
3gLudeH22A
Jan 11, 2003 06:58 PM
Black R
Dec 19, 2001 09:29 PM
LudeSi-93
Jun 18, 2001 01:07 PM
