Honda Datalog for Android
Old Aug 19, 2011 | 09:25 AM
  #26
mikesrex's Avatar
Default Re: Honda Datalog for Android
do android phones have accelerometers?
Old Aug 19, 2011 | 09:28 AM
  #27
Peter Linszter's Avatar
Yes. Every android phone have accelerometer sensor.
Old Aug 19, 2011 | 02:30 PM
  #28
josephcmiller2's Avatar
https://market.android.com/details?i...=search_result
This is what I use.
Old Aug 19, 2011 | 06:01 PM
  #29
joppe's Avatar
Does it work with ectune? Site says: It's only supports OBD1 (Crome) at the moment. (It's supports other ECU-s later)
Old Aug 19, 2011 | 08:51 PM
  #30
I can't test the app with eCtune yet, so it's supports only Crome at the moment. I wrote the eCtune datalog protocol to the app, but i don't now how is it working.
Old Aug 20, 2011 | 09:28 AM
  #31
joppe's Avatar
I have allso omnipower 4bar map sensor. Can you add it? How about injector duty %? I think this is gonna be great with little upgrades.. I allready ordered my bluetooth for cn2
Old Aug 20, 2011 | 10:34 AM
  #32
I can add omnipower map sensors and i think injector duty too.
Old Aug 20, 2011 | 11:20 AM
  #33
THC07's Avatar
isnt this the same thing as the OT-2?
Old Aug 20, 2011 | 12:46 PM
  #34
joppe's Avatar
Seems that OT-2 is for obd2 and much more expensive than this. This is for obd1 ecus. And obd0 on progress too? obd0 stuff is great because i used it several years until i got vtec engine and obd1 swap.
Old Aug 20, 2011 | 12:57 PM
  #35
I have 4 datalog protocol in the app, but only obd1 crome supported yet, because i can't test the other 3 protocol (obd1 ectune, obd0 bre & turboedit ng63). The OT-2 is OBD2.
Old Aug 23, 2011 | 02:21 AM
  #36
K20egcw's Avatar
The datalog app is now released!
Datalog app link
https://market.android.com/details?i...r.hondadatalog
Old Aug 23, 2011 | 04:05 AM
  #37
I'm getting the adapter first, then I'll definitely be getting this app.
Old Aug 23, 2011 | 04:33 AM
  #38
SQ is the SQUAD's Avatar
i got my adapter on ebay, took 2 weeks to come in.
Old Aug 23, 2011 | 10:11 AM
  #39
I went for this one because it is states-side
http://www.ebay.com/itm/TTL-Bluetoot...#ht_923wt_1225
Old Sep 7, 2011 | 08:17 AM
  #40
Free DEMO for testing the connection
Old Nov 5, 2011 | 07:45 PM
  #41
baz_ctr's Avatar
is this all i need to add to the crome ecu for this to work?
http://www.ebay.ie/itm/Arduino-Seria...item3a6c3d1ab3
Old Nov 28, 2011 | 05:52 PM
  #42
The first TTL I ordered was lost in the mail so I ordered a second one. http://www.ebay.com/itm/230706362179...84.m1439.l2649 I re-pinned my data cable and then paired it with my laptop and my Android. I got no response from the ECU. Not garbage data, just nothing. No readings at all. LED goes solid once connected but no sensor readings are transmitted. I'll double-check the wiring tomorrow but maybe I've got the wrong one?
Old Nov 29, 2011 | 11:00 AM
  #43
Some of these device has wrong default settings. Please wait few weeks. I ordered a moates obd1 engine simulator. When i got it, i make some fix and add new features ot the app, and i'll write a "how to.." article about these BT devices.
Old Nov 29, 2011 | 11:48 AM
  #44
I think it has the wrong baud rate. I'll try to change it when I get home tonight and post my results. Thanks.
Old Nov 29, 2011 | 05:37 PM
  #45
joshua54915's Avatar
has anyone been able to find the bluetooth adapter??? im interested in the app but i want to know i can get that adapter
Old Dec 22, 2011 | 04:21 AM
  #46
baz_ctr's Avatar
I have same problem I have bluetooth connection but no data how do i fix this?
If it is the bandwidth how do I change that total novice when it comes to the auto electronics
Old Dec 22, 2011 | 07:34 AM
  #47
Your bluetooth device must be set to 38400,8,N,1 in order to be properly set up for the serial port on the ECU. You will need to contact your bluetooth device supplier or the manufacturer to find out how to change it. You may have to send it to someone to change it for you.
Old Dec 22, 2011 | 08:29 AM
  #48
baz_ctr's Avatar
thanks lad advice most appreciated I will get on to supplier now
Old Dec 22, 2011 | 12:31 PM
  #49
Some help for the bluetooth devices
Old Dec 22, 2011 | 12:54 PM
  #50
gwarfare's Avatar
So sick, I want my phone to do that.
