High load idle (column7-9)
Old Jun 5, 2012 | 06:48 AM
K20EF8Dx's Avatar
Default High load idle (column7-9)
Had some bad luck with software lately, Ectune was locked out so i purchased Crome pro which worked then logger messed up (has yet to find fix).
Anyways, i had to use crome since was locked out, car has no iacv, got car to idle and was working on a few things. i noticed in certain areas nothing was changing (remember this was blind because logger doesnt work). i pulled timing to 0 accrossed the board and found at column 7-9 (wot) changed. we have tried another map sensor and still same spot. also double checked wiring to make sure something wasnt plugged in incorrectly. Have not gone to alpha n yet but car should work fine on stock map sensor for now.
Ectune is working again and will venture out their to see. just would like some input on where to start so i can address as soon as possible.
Specs
B20z2 block
p73-00 pistons
b16a head
ctr intake cam
93 Gsr exhaust cam
2.75 skunk 2 megapower exhaust vibrant big tube header
Accel high impedance 370cc injectors
obx- r itbs
Thank you.
Old Jun 5, 2012 | 04:02 PM
Gunmetal_B20_Hatch's Avatar
Default Re: High load idle (column7-9)
Are you using a vacuum reservoir or a balance tube with the ITBs?
Old Jun 5, 2012 | 08:50 PM
K20EF8Dx's Avatar
yes each itb is ported to a vacuum manifold.
yessewey
15
Mar 9, 2010 06:45 PM
tial-eg
Jan 9, 2009 03:21 PM
heyitzspikey
Jan 29, 2007 09:19 PM
JMvtec
20
Nov 14, 2006 06:47 AM
Ryanwb
Mar 31, 2003 03:41 PM
