help getting 2.5 motorola map sensor to work?
Old Aug 22, 2011 | 09:37 PM
RiipTiide67's Avatar
Default help getting 2.5 motorola map sensor to work?
I'm having one heck of a hard time getting my car running on a 2.5 bar motorola map sensor. I have a chipped p28, and a chipped p06 converted to vtec.
I can run both ecu's without jumpers/chips with a stock map sensor fine.
I can run both ecu's from a burned chip (simple unmodified basemap) with a stock map sensor just fine, although on both ecus i get a solid check engine light when running from any chip.
When i burn a chip with the 2.5 bar motorola map sensor "calibrated" on the rom i get a solid check engine light, and my car starts up and dies immediately. If i take the chip out and run a stock ecu with the 2.5 map sensor installed on my car, it starts and stays running, but barely (which makes me think i "calibrated" it wrong)
anywho, i open up my .bin in crome, go to plugins>advanced boosttools+, click ok, click next, select 2.5 motorola map sensor, select 6 boost columns, and select next. is this the correct way to tell the rom to read the 2.5 bar map sensor instead of the stock map sensor? How else would I calibrate it?
anyway, any help would be greatly appreciated. any information, any experience, anything that i can try or troubleshoot. i've been working on this for nearly two full days and i'm stumped. thanks for your time.
Old Aug 23, 2011 | 03:54 PM
Gunmetal_B20_Hatch's Avatar
Default Re: help getting 2.5 motorola map sensor to work?
sounds like you may need to remove checksum routine
Benny Bao
Oct 14, 2014 11:47 AM
lch
Apr 17, 2007 07:27 AM
EK k kay
Nov 2, 2006 01:04 PM
NA JDM GSR
Oct 29, 2006 08:38 AM
quickchris
Jul 28, 2006 09:47 AM
