heat temp gauge
Old Feb 5, 2010 | 07:11 AM
Arthas's Avatar
Default heat temp gauge
hey,
yesterday as I was driving for about 1 hour straight , I noticed that my heat temp gauge needle was closer to the Cold, normally it would sit right in the middle , or if its overheating it would move more twords the Hot. I didnt think of it much, and today as I was driving (while raining , so it was kinda cold) my cars neddel was jumping from Cold to the middle of the gauge , as I was paying attention more to it, I notice that when I was at a stop light , my car's neddle was almost at the Overheating part, but when Im driving the car, and not stopped, it goes back to cold... Is their a way to check if the gauge is working, or what could be the problem??
1996 integra
Thanks
Arthas
Old Feb 5, 2010 | 08:36 AM
dpetro1's Avatar
Default Re: heat temp gauge
check the wire running to the 1-pin dash sensor. #13 in the pic. chances are the wire or connector has gotten cracked/broken from years of heat cycling. if the wiring is in good shape then replace #13
if neither works then repalce the thermostat, it may be sticking
Old Feb 7, 2010 | 01:17 AM
Arthas's Avatar
Is 13 the temp sensor?
Old Feb 7, 2010 | 01:13 PM
dpetro1's Avatar
yes, #13 is the temp sensor for your dash gauge. it has a 1-wire connector on it
Old Feb 8, 2010 | 09:52 AM
Spunkster's Avatar
Before doing that make sure the fan is working correctly
Max Murray
Jul 16, 2016 09:07 AM
95accordlx
12
Mar 18, 2015 05:26 AM
the soL that could
Mar 14, 2009 06:20 PM
boarding2008
Feb 1, 2009 04:00 PM
1991hb
11
Oct 21, 2006 08:31 AM
