GSR basemap/ CRome = Solid CEL
Old Aug 12, 2010 | 07:43 PM
mouab18c1's Avatar
Icon2 GSR basemap/ CRome = Solid CEL
Alright so on crome I burn a stock basemap supporting IAB's for my brothers stock gsr. It throws a solid CEL. Tried a different map on the same chip no solid CEL. Tried same stock gsr basemap with same chip on different ECU it also throws a solid CEL. Cant seem to figure it out. Anyone have this issue before?
Old Aug 12, 2010 | 08:56 PM
GhostAccord's Avatar
Default Re: GSR basemap/ CRome = Solid CEL
Sounds like it could be a bad basemap, try burning it again. Did you remember to remove the checksum routine from the map before you saved/burnt it? Also remember to add the Quick Datalogger +RTP on there as well.
Old Aug 12, 2010 | 10:35 PM
mouab18c1's Avatar
Its just the basemap that Crome has on its free version. But I will try it again.
Old Aug 12, 2010 | 11:11 PM
OK, You mean the base ROM file that you open in Crome just to start off with. After you open that you need to go up into the plugins menu click on Enhancements and then click on the "Remove Checksum Routine" button. Then save it/burn it to the chip.
Old Aug 13, 2010 | 11:46 AM
mouab18c1's Avatar
kool, just did it. I'll see if that was the problem.
Old Aug 13, 2010 | 01:21 PM
mouab18c1's Avatar
Not working. Still solid CEL. Anyone got a stock p72 map they can send me?
Old Aug 13, 2010 | 02:21 PM
majdi's Avatar
Are you using USDM or JDM bin?
Old Aug 13, 2010 | 06:04 PM
mouab18c1's Avatar
Crome bins should be usdm
Old Aug 13, 2010 | 10:23 PM
Only if you choose the USDM ROM profile
However the P72 ROM base in Crome is USDM
Email sent! Let me know how that works for ya
Old Aug 13, 2010 | 10:25 PM
mouab18c1's Avatar
Free Crome version does not have the option of choosing a Usdm or JDM rom. It only has the USDM. How do I disable full throttle launch on Crome since the Bin you sent me already has the feature.
Old Aug 16, 2010 | 05:40 PM
majdi's Avatar
Hey cant you solve this problem? disable full launch control? i also got this problem
Old Aug 16, 2010 | 06:53 PM
Why do you need it disabled? It doesn't hurt anything having it on there.
If you want to disable it, put it higher than your rev limit.
Old Aug 16, 2010 | 07:20 PM
mouab18c1's Avatar
Thats what I thought. My brothers car does not have the speed gear since some dummy that rebuilt it left it out. So it throws a cel for the Vss. With two step activated the car will redline at whatever rpm it is set at since two step is deactivated by speed. So ill be setting two step launch at 8500 to work as his redline.
Old Aug 16, 2010 | 08:57 PM
There are a few other things that are speed actuated/calculated as well. Probably not going to work all that well until you get the VSS fixed.
Old Aug 16, 2010 | 09:39 PM
mouab18c1's Avatar
Yea I understand. He was currently running on a jdm p30. Car ran like **** and no Vtec since the Vss was not installed. The cheapest route to make it perform like an actual Gsr was to get a p28 and disable Vtec speed check. Car runs smooth now with the new chipped ecu. Just had that stupid solid CEL with the Crome basemap. I havent had time to install the new chip I burned with the basemap you sent me yet. I'll be doing that tommorow ill let you know how it goes.
Old Feb 29, 2020 | 09:35 AM
gasFace -'s Avatar
@GhostAccord can you send me a b18c1 basemap as well. cromes basemap doesnt work for me.
Old Feb 29, 2020 | 04:40 PM
n*werk's Avatar
LoL 10 years later
07Lxcoupe
Engine Management and Tuning
Sep 4, 2011 05:18 AM
Vtec92Civic
Mar 30, 2005 11:54 AM
Vtec92Civic
Mar 29, 2005 11:16 AM
LST
Oct 22, 2004 08:48 AM
