G23 basemap needed
Old Oct 16, 2020 | 08:43 AM
Jose Villalobos's Avatar
Default G23 basemap needed
I'm new to this forum and am looking for some help. I just put together a "g23" engine and am looking for a basemap to help me. I am using a stock f23 block and stock h23 head. I have a chipped p28 and am using crome to tune. I tried using my stock h23 basemap but it would run. I tried a few other maps but no luck. I'm hoping someone has a map I could use to start with and tweak if needed. Thanks for your help.
Old Oct 21, 2020 | 07:34 PM
GhostAccord's Avatar
Default Re: G23 basemap needed
An H23 or F23 base map should be more than enough to get you up and running well enough to tune.
What seems to be the problem when you are running the H23 map?
Old Oct 24, 2020 | 01:40 PM
I tried running my stock h23 map and it started surging like a was missing a vacuum line. I went through it and checked everything. It was all connected and in the correct locations. I redid the timing just to be sure. It still doesn't idle smoothly just revs from about 700 up to about 1100 and back down. I messed with the distributor timing to see if that changed anything and also the idle control screw on the throttle body. Nothing seems to work. I tried driving it around the block and it doesn't really accelerate even though I'm flooring it. So I was hoping someone had a map that I could try that's been tuned a little bit not a stock map like I'm currently running. Thanks for responding.
Old Oct 26, 2020 | 03:23 PM
Check your TPS and MAP sensor connections, these can be switched and overlooked. The car will run with them switched, but not properly. Just something to check.
I will have a look and see if I have a tune for a G23 in my files. Any of the ones I would have would have been for the H22 head on an F23 bottom end though. I don't recall that they were all that different from stock except for adding VTEC, which you don't need.
Old Oct 26, 2020 | 03:35 PM
I tried a new TPS sensor thinking that was an issue but didn't change anything. The map sensor has a different plug then my TPS so I know they're not backwards (thankfully). I appreciate you looking for me.
Old Oct 26, 2020 | 03:44 PM
What chassis is this going into?
What type of MAP sensor are you using?
Old Oct 27, 2020 | 09:17 AM
It's a 93 accord sedan using the stock map sensor. I had a stock h23 in it before with no issues until I tried this g23
Old Oct 28, 2020 | 06:22 AM
FaceTuned's Avatar
IACV unplugged or wrong plug?
Old Oct 29, 2020 | 06:05 PM
I went through the whole harness and double checked everything and it's all in the right place. I'm just going to get a new block and start over. Thanks for your help though.
Old Jul 15, 2023 | 08:55 PM
Honda_trueno's Avatar
If you do find it can you send it to me. My g23 should be finished soon (f23 block h22 head) and ima need a base map. Thank you!
Old Dec 9, 2024 | 06:56 PM
the_hnda_trueno's Avatar
Hey if you're still active I'm just wondering if you figured out the issue along with if you have the basemap still? Thank you!
Old Jun 26, 2025 | 10:04 PM
ej8ru's Avatar
ima need that base map
Old Feb 4, 2026 | 09:34 PM
Maks Oleo's Avatar
Bro, please send basemap g23
