Flushing and replacing all fluids in my car
Old Mar 4, 2012 | 06:05 PM
tripsixblake's Avatar
Default Flushing and replacing all fluids in my car
I don't really want to pay jiffy lube to do it for me and I would like to know how to do it myself. I bought a 5speed 99 civic ek a month ago and everyone is telling me that I need to flush the fluids and change it. I got an oil change already so I wanted to know if anyone can tell me how to flush all the fluids and put new fluid in. So if anyone can give me a simple but informative step by step guide or a video it would be much appreciated! Thanks
Old Mar 4, 2012 | 07:02 PM
j-r_rida's Avatar
Default Re: Flushing and replacing all fluids in my car
well you should gotten a engine flush when you got a oil change, but a coolant & radiator flush can be done with a water hose & a bucket.... i do believe that there are some write ups on this site to do both.... check them out, use the search button
Old Mar 5, 2012 | 12:12 AM
BobbyRodriguez's Avatar
Oil is easy - we all know oil
Coolent is easy still - just remove bottom radiator hose or undo drain plug!
Power steering - remove resivor and refill
Brakes and clutch - use hand vacuum for lines
Gas - seafoam it! ! !
Greas is greas
Old Mar 8, 2012 | 05:01 PM
Kongs92si's Avatar
Get a Haynes manual. Best manual ever. Theres step by step on all fluids.. For transmission fluid, you can either use differential fluid or engine oil. 5w-30
What bobby said. I recommend using 50/50 coolant to flush instead of water. Water and metal means rust..
tripsixblake
Engine Management and Tuning
Mar 5, 2012 12:15 PM
1992honda
Sep 27, 2011 04:28 PM
MikNomis
Sep 16, 2011 04:47 PM
AdRoz
Transmission & Drivetrain
Jun 14, 2010 10:36 AM
oddcivic
Feb 7, 2002 12:22 PM
