Engine management upon engine start-up guidence?
Old Sep 30, 2008 | 07:42 AM
ys1civicsi's Avatar
Default Engine management upon engine start-up guidence?
Well since i am new to the boost industry I have yet to explore engine management. The setup is a 9.0:1 Compression Ls/VTEC bored to the typical 81.5mm for a fresh cylinder walls. i am running stock GSR cams for now I have 450 DSm injectors but plan to use 880cc precisions. If there are any other questions about the setup please ask, as I am asking for your help. How do you recommend starting this motor, should I swap in the stock B-series injectors and run it as a stock motor to break it in as I WILL NOT HIT BOOST or break it in on the dyno? What do you guys recommend for engine management? I have heard a lot about Neptune/Hondata etc or should I let me tuner decide when I show up for the appointment. Basically i am asking you guys to help me out so this motor lasts and does not run to lean/rich during break-in so the motor does not blow. Sorry for such a long post I just wanted to get the point across so i can get the most info about this problem. Also how should I go about getting the ECU setup i have a STOCK JDM P30 Short box and a Stock P28. What is the best Ecu to start out with? I know The s300 supports both so please let me know your opinions and once again sorry about the long post. Also tuner will be JEff Evans
Old Sep 30, 2008 | 08:22 AM
HRTuning's Avatar
Default Re: Engine management upon engine start-up guidence? (ys1civicsi)
Jeff can socket the ECU. I'd recommend sticking with the P28 since you could get more for the P30 if you sell it.
If you don't plan on making any changes to the tune, go NepTune. If you want to be able to make some changes, go NepTune RTP. If you need on-board logging, go s300.
Old Oct 1, 2008 | 03:05 PM
19slocivic97's Avatar
neptune
cust. service
Old Oct 1, 2008 | 03:58 PM
ys1civicsi's Avatar
Default Re: Engine management upon engine start-up guidence? (19slocivic97)
Any other opinions out there Neptune RTP vs Hondata S300 my decision has been filtered down between these 2
Old Oct 1, 2008 | 04:03 PM
HRTuning's Avatar
If you want on-board logging, get the s300. If not, get the RTP.
Old Oct 2, 2008 | 05:55 AM
ys1civicsi's Avatar
Default Re: Engine management upon engine start-up guidence? (HRTuning)
thanks man anyone else bump
Old Oct 2, 2008 | 12:10 PM
CIVICTUNER04's Avatar
Jeff is an awesome dude really knpows his **** im running regular neptune now dont have money for s300 now but if uhave the money get s300 JEff will prolly agree im getting retuned next friday
mykulangot92
Dec 3, 2010 06:00 PM
adeihl
Sep 1, 2005 07:38 PM
PnoyJeff
Jul 29, 2005 04:32 PM
didz
Mar 10, 2005 07:13 AM
revhrdls
Aug 30, 2001 09:15 AM
