COP Trigger Setup
Old Oct 16, 2025 | 11:54 AM
  #26
spAdam's Avatar
Loved
Community Favorite
Default Re: COP Trigger Setup
Make yourself a sub harness that has your distributor plug on one end and the cam/crank sensor connectors on the other end. Pin the cam and crank sensors to the CYP and CKP sensor locations, respectively.
You'll still need to run four wires from the ecu to the coils for signal. You can use the TDC wires and the original ICM wire for three but come up short by one, so might as well just run the four wires separately.
For the tach signal, easy button when deleting the distro is to run a wire across the dash inside the cabin and tap into the original ICM pin the ecu. Obviously this will not be active on the Link if you have it set up for COP, but you can easily configure it as a tach output in the software.
Your coil pack subharness is easy, you have 12V coil power at the second distro plug and you can use a ring terminal to ground to one of the distro mounting lugs. Then you just need your 4 coil signal wires. Done and done.
Old Oct 25, 2025 | 05:13 PM
  #27
Sway5000's Avatar
Originally Posted by ls joker
Looks like you purchased the linkecu hc92x. On that ecu, you would need a tach booster for that plug in board. Id also recommend the k24 cam sensors, due to ths plug orientation pointong downward. For the connectors and pins, i ordered racespeconline. Theres pinouts obviously in the help file or in the hc92x manual. You would then have make sure you have the specific cam sensor wiring. K20 and k24 have different wiring positions. I got that information from haltech i believe. Unpinned the distributors pins, pinned in the cam sensor pins into correct location.
Im pretry sure i still have my notes from when i made the harness and did all the wiring. if you need help with anything just pm me. Or start a thread
Yes I have the HC92x Link ECU. I've figured out that people have been depinning the plug at the dizzy or making a sub harness. I figured someone would offer one, but that isn't the case. Would you happen to have the part numbers for the K24 Cam sensors? I have seen somewhere that the actual length of the sensors are different depending on which ones are used so I know that is something to possibly beware of.
Old Oct 25, 2025 | 05:15 PM
  #28
Sway5000's Avatar
Wiring is not my thing at all. I would figure someone would offer a subharness, but clearly I'm mistaken. I may jump out there and make a sub harness, but I'd much rather leave it to a professional. Now that I have the wiring outputs from the thread on the Link forums, I feel more confident as far as knowing what needs to go where exactly.
Old Oct 25, 2025 | 06:27 PM
  #29
ls joker's Avatar
Loved
I made a separate harness incase i needed to quickly switch back to my gutted distributor coil on plug setup. it was actually really easy. Left the dizzy plug and pins intact at both ends. Just depinned the ecu side. Joined the 12volt and ground source for both sensors. Ckp and cyp would be based off of the ecu pinouts. Again make sure you check out the correct pin location for the specific cam sensors. Let me know if you need help with how i did my harness. Pretty sure i had pics in my build thread
Old Nov 10, 2025 | 05:00 PM
  #30
Sway5000's Avatar
Hondata just released something similar to the Honed setup, but with an entire new harness as well to run KPro. Very interesting.
Old Nov 10, 2025 | 07:57 PM
  #31
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
The B-Pro is not actually "released" just yet... a pre-production unit has been exposed at SEMA 2025 last week. It isn't even listed on their official website yet. This system should be ready for public consumption in early 2026.
RattyTuned
Feb 9, 2012 11:07 AM
Mangudai
Jan 12, 2009 12:07 PM
ITR-EKcoupe
Jan 3, 2009 09:08 PM
2DoorBandit
22
Jul 4, 2008 01:01 AM
pr0honda
Jan 2, 2008 06:44 PM
