chrome launch control will not work!!?
If all else fails you can just buy a stutter box that does ignition cut launch control and install it, not ideal I know, but it would get you launch control...
Make sure your TPS is properly calibrated, you can check raw voltages with Freelog if you don't have a voltmeter.
Otherwise, use a new ROM. Using the custom TPS plugin in a P30 base can jack up the file, so if you have abnormal TPS voltages then your best option is a gold file or an OEM TPS.
still to this day i have tried everything there is besides switching out the bar harness and dash harness, this will still not work. i just recently got a new throttle body for this car and recalibrated tps and still nothing. talk about bringing a thread back from the dead but damn i wish this would work
91b18a1ls
Engine Management and Tuning
10
Dec 9, 2019 02:27 AM
Mitchell Smith
Apr 28, 2019 08:41 PM
Vtec Civic 93
10
Sep 2, 2010 08:52 PM
