b16 throttle body help
Old Dec 29, 2008 | 02:34 PM
craigb16a's Avatar
Default b16 throttle body help
where do the vacume hoses go
Old Dec 29, 2008 | 02:55 PM
93turbo16's Avatar
Default Re: b16 throttle body help
It might help if you had specific hoses or gave us atleast the car and what motor you are working with.
As obd0 b16 and obd2/obd1 b16 tbs are a little different.
Old Dec 29, 2008 | 03:15 PM
craigb16a's Avatar
sorry my jdm b16 p30 throttle body does not have a map on top of it just 2 hoses where do they connect on a 97 usdm civic del sol s d16 model
Old Dec 29, 2008 | 03:16 PM
93turbo16's Avatar
The larger of the two goes to the charcoal canister.
The smaller one goes to the map sensor, you might have to take one off of another car or find one from an OBD0 civic.
You can use the stock civic sensor, just zip tie the little hose onto it.
craigb16a's Avatar
does the jdm obd1 b16a even have a map sensor
Old Dec 29, 2008 | 03:17 PM
craigb16a's Avatar
cool thank you can i just bUY a different throttle body and use the d16 map
Old Dec 29, 2008 | 03:19 PM
93turbo16's Avatar
Sure. You could use say an LS throttle body on there which has the map sensor on top of it.
Old Dec 29, 2008 | 03:23 PM
craigb16a's Avatar
what about all those purge valves do i need to connect them as well
Old Dec 29, 2008 | 03:24 PM
craigb16a's Avatar
and would any cr-v b20 throttle body work
Old Dec 29, 2008 | 03:25 PM
93turbo16's Avatar
As long as it has the map sensor on the top, it should work. I haven't taken many of them off so I am not 100% on that one.
But if you need to pass inspection i would try to keep as much of the emissions stuff as possible intact.
Old Dec 29, 2008 | 03:27 PM
craigb16a's Avatar
the original charcoal canister has 3 nipples which one goes to the top of the T.B.
JDMCivic16
Jun 25, 2009 11:29 AM
b16delsol
May 17, 2004 09:06 PM
b16delsol
Mar 19, 2004 02:41 PM
