AEM Series 2 EMS connectivity issues- Solved
Old Aug 24, 2025 | 01:26 PM
10SecEK9's Avatar
Default AEM Series 2 EMS connectivity issues- Solved
One day I went to go start my 2000 Si running a V2 ems. Wouldn't run the fuel pump or connect to the laptop after cycling the key a few times.
Check all fuses, ECU fuse was fine
start unplugging random connectors
Boost solenoid on C10 was the issue, it was stuck on and would stop the ecu from working correctly
Hope this helps anyone with the same issue. I've spent 2 weeks checking everything, who wouldve thought it was a damn boost solenoid.
Old Aug 24, 2025 | 07:46 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: AEM Series 2 EMS connectivity issues- Solved
Nice find. Now what do you do about boost control ?
crazyjetsfan22
Jul 30, 2015 12:18 PM
Civictuned2800
Jan 9, 2015 08:09 PM
1hatch2nv
Oct 7, 2012 03:09 PM
mister2racer
May 10, 2004 07:56 AM
