Adding addtl. sensors on AEM V2
Old Mar 2, 2016 | 08:39 AM
ohsnapzafingcu's Avatar
I serve phở for my babies
Default Adding addtl. sensors on AEM V2
Hey all,
I am needing to add in a few additional sensors on my car with AEM v2. Sensors below:
  1. E85 content sensor
  2. fuel pressure sensor
  3. water temperature sensor
  4. wideband
  5. IAT sensor
  6. MAP sensor
So this leads me to three questions:
1. Can I just wire in the AEM water temp sensor to the factory water temp wire to where it sends a signal to my gauge cluster then to the ECU? or will that cause interference and an inaccurate reading to my ECU?
2. Can I wire in the AEM map sensor to my factory MAP sensor plug?
3. Can I wire in the AEM IAT sensor to the factory wires?
Will all these sensors need to be scaled inside AEM v2 for them to read accurately?
I understand all sensors have to be calibrated, but with the fuel pressure sensor is there a table I can follow that determines how much pressure I have VS voltage? Same with IAT, and Water temp.
thanks!
Bryson
Old Mar 2, 2016 | 08:44 AM
Tufflexveritiv's Avatar
Look in the wizards
If youre using all aem sensors then the wizard will automatically adjust them
Make sure you add in the pull up resistors appropriately
I think its needed for the fuel pressure or oil temp sensor
Old Mar 3, 2016 | 06:48 AM
Default Re: Adding addtl. sensors on AEM V2
resisters? uh oh!
ok thank you!
DA 4 Lyfe
Feb 2, 2015 02:45 AM
antcrxls
Engine Management and Tuning
Jan 18, 2014 02:02 PM
spdrmn
Jun 29, 2012 01:22 PM
GT30EK
Feb 13, 2012 04:21 AM
93TurboSi
Mar 3, 2005 12:14 PM
