Z6 Crank into Y7 Block
Old May 4, 2020 | 11:21 AM
Lazysohc's Avatar
Default Z6 Crank into Y7 Block
New to the forum probably starting off on a bad note. I have searched and everyone has been quite vague of what is compatible with what and what is needed to make things work. I currently have a Y7 D16 block, oil pump, oil pan and have a brand new Z6 crankshaft I'd like to use in my rebuild. I understand that the timing will be different if possible but will I be able to use the Y7 pulley on a Z6 crank? What issues will I run into other than timing? If I have the y7 pump with the dipstick why would there be a difference with what crankshaft I use? I appreciate the help, thanks.
coltron420
May 3, 2019 01:54 PM
bnmm
Nov 10, 2011 11:27 AM
TylerLorenz
Feb 7, 2010 07:01 PM
slob20ef
Sep 30, 2009 10:12 AM
HiProfile
Oct 10, 2006 06:19 PM
