z6 crank in a a6 block will it work?
I have a d16a6 im building and the crank is no good i can get a z6 crank and was wondering if it would cause any problems? also will the z6 oil pump and timing gear work? Im building a vitara'd a6/ z6 head and dont want timing issues. Thanks alot
1 Post
Re: z6 crank in a a6 block will it work?
a6 block is the same thing as a z6 block except the head is basically a b7 head. excluding water pump & tensioner eveyrthing else should be the same. I have a a6 crank in my z6 just make sure the rod and main cap bearing clearances are the same
SpoonfedCivic
02-23-2011 07:30 AM
