Siezed crank
Old Jun 14, 2019 | 11:51 AM
cordillera auto's Avatar
Icon5 Siezed crank
am doing a z6 engine rebuild and checked my clearances and they were within range. I put oil onto it (am planning on installing immediately after rebuild) and then torqued in sequence to 32 ft lb at this point the crank was still rotating. when i torqued it to the 53 ft lb the crank wouldn't rotate at all. what could cause this?
Old Jun 14, 2019 | 08:28 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Siezed crank
You either have a rod or main cap turned around during final installation/torque or the crankshaft is bent.
Old Jun 16, 2019 | 11:51 AM
Ryanthegreat1's Avatar
dirt/oil under the bearing shells.
