Quick H series question
Old Feb 23, 2020 | 10:29 AM
The_Head's Avatar
Default Quick H series question
What's the largest bore you can do on a sleeved H-series? I was hoping to re do my engine to go forced induction. The current bore is 89mm, the sleeves are "LA" sleeves. Can I bore it out to 89.25 and not have issues?
Old Feb 23, 2020 | 09:27 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Quick H series question
Yes, but that will be a tough piston to find. If you intend to boost this engine, you should probably go smaller. Bores that big leave limited gasket material between cylinders and thus, the chances of blown head gaskets are more common.
Old Mar 16, 2020 | 03:46 PM
Dohcit's Avatar
87mm for boost and 90mm N/A??
tollickj
Jul 24, 2014 01:20 AM
b18b1hondacrx
Jan 22, 2011 03:05 PM
bzyq2001
Aug 1, 2008 01:53 PM
JDM_COUPE
Jan 3, 2007 10:10 PM
zdiddycustoms
Mar 15, 2006 04:22 PM
