Piston diameter measurement.
Old Aug 9, 2019 | 10:26 PM
Brembomaster's Avatar
Default Piston diameter measurement.
Hello, I am measuring the diameter of 82MM YCP piston to do the piston to wall clearance.
Why my set of piston middle measure point diameter 0.03mm larger than the skirt? As my knowledge, the skirt of piston is the biggest point in the normal.
My measurement:
Piston middle : 81.99mm
Piston Skirt: 81.96mm
Is it normal? And which measurement I should use for do the clearance?
May I do 0.05mm clearance for piston skirt? If not , how many clearance for my set piston should be fine?
Old Aug 10, 2019 | 05:46 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
Default Re: Piston diameter measurement.
You will need to contact the manufacturer to see where you do the measurement. It may not be the same spot as OEM pistons.
Boyle.R
Jun 21, 2014 12:38 AM
DC2TT
Nov 11, 2005 10:44 AM
Sliced Beard
Jan 22, 2004 06:55 PM
98Psi ITR
Jan 26, 2002 08:52 PM
