Mix matching main caps on a b18b1
Old Jun 21, 2017 | 01:03 PM
toxictom's Avatar
Default Mix matching main caps on a b18b1
Hello, well I am trying to rebuild my b18 after blowing 2 craigslist motors. I have 4 blocks (2 the mains and rods are shot)... anyways when I took apart the first 2 bottom ends I never matched the main caps with the blocks... so now I have a bunch of main caps... Can I pick the ones that look the best condition and mix and match them? I was thinking I could use a bore gauge to measure the mains after they are tourqed down with no crank to make sure I am round... Is this okay or am I better off looking for a new block?
Old Jun 21, 2017 | 08:49 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Default Re: Mix matching main caps on a b18b1
Swapping main caps from the original ones REQUIRES a fresh line hone of the main journal bores. Usually, the color of the block's internal surfaces is a good indicator of which caps go with which block... however, if you still feel like you are "guessing" on which go where... pony up the dough for the machine work or find a virgin block... WITH MAIN CAPS.
Old Jun 24, 2017 | 10:28 PM
motoxxxman's Avatar
this. 100% this
pettyboy69
Apr 18, 2013 06:09 AM
b00stedOne
Jun 29, 2010 12:59 PM
Godspeed07
Nov 13, 2007 06:38 PM
rmcdaniels
Apr 29, 2005 09:51 PM
stayontrack
Sep 19, 2002 04:59 PM
