lost motion kit
Old Jul 10, 2015 | 12:16 AM
philcivicjordan's Avatar
Default lost motion kit
So im rebuilding my engine ready for when i strap a turbo too it. While ordering some bits i needed for it i came across lost motion kits for my engine and i have a few questions to ask. I've read up on valve spring design and can see how the lost motion spring is a better design then two separate springs.
Im guessing they replace the inlet valve springs?
Also ive seen skunk 2 and honda ones for the same price, skunk 2 mention having hardened tips and not needing collars to lock them in. However for the honda ones nothing like this is mentioned, so im guessing they still slot in like the old ones?
And will i notice a difference with boost
Old Jul 10, 2015 | 04:47 AM
OneBadTurboCRV's Avatar
DO IT ON ALL FOURS
Default Re: lost motion kit
2 separate springs? Inlet valve? S2 and OEM the same price? Locking collars? Notice a difference with boost?
Just what type of engine are you talking about exactly?
Old Jul 10, 2015 | 04:50 AM
B16a2
Old Jul 10, 2015 | 05:01 AM
DO IT ON ALL FOURS
In that case there isn't any of the following: two separate springs, contact with any valves, same price, locking collars, and absolutely nothing to do with a boosted engine. That's not how the LMAs work... they only support the VTEC rocker arm when you aren't in VTEC to keep it from flopping around and causing damage. It doesn't have anything to do with what you mentioned and the OEM ones are more than double the price of the Skunk2 ones. You need to double check all your information sources.
Here is a picture of the difference between the old "hydraulic" type LMA and the new spring type LMA.
Old Jul 10, 2015 | 05:07 AM
PyroProblem's Avatar
I think you are confusing LMA/ lost motion assemblies with valve springs.
Old Jul 10, 2015 | 05:09 AM
The example to the right i do not have in my engine it looks more like two seperate springs that inside eachother.and this was the inlet side.
The engine only had 70k on it so i doubt its been rebuilt either. Maybe im cobfused to where the lost motion kit goes
Old Jul 10, 2015 | 05:14 AM
DO IT ON ALL FOURS
If you are in fact talking about VALVE SPRINGS on the INTAKE side then that's how the B16A2 comes from the factory. Double spring on the intake valves and a single spring on the exhaust valves...
Honda Automotive Parts
Tell us what part number in the picture.
Old Jul 10, 2015 | 05:21 AM
Yeah 10 and 11 is what im talking about. I was guessing the lost motion kit replaces that design?
Old Jul 10, 2015 | 05:34 AM
DO IT ON ALL FOURS
Again, you aren't listening... the LMAs have nothing to do with the valve springs. They are a seperate system all together and operate 100% independently of the valve springs. To put it VERY roughly - The valve springs are to keep the valves closed and the LMAs are to keep the VTEC rocker from slapping around.
The new designed LMA "kit" replaces part #16 in the diagram. I highly suggest you get a factory service manual or consult a professional if you are going to try and take your engine apart.
Old Jul 10, 2015 | 06:01 AM
Okay i undestand that now and the message before i thought these replaced the valve spring initailly. I read a really detailed article on valve springs pretty sure lost motion was mentioned there, so thats where that come from. So is this a worthwile upgrade. I can get honda ones for the same as skunk 2.
Honda
http://japserviceparts.co.uk/civic/honda-civic-ek-series-96-00/engine-parts/honda-lost-motion-assembly-full-set-b-series.html
S2
http://www.funkypower.co.uk/catalogue.php?make=honda&model=INTEGRA&year=1995-01+DC2+INTEGRA+TYPE+R&level1=ENGINE&level2=LOST+MO TION+ASSEMBLY+KITS&level3=&id_product=7890
Old Jul 10, 2015 | 06:05 AM
Its already apart there was no trying.
It ready to go back together im just waiting on parts. And replacing anything worth replacing while i wait
Old Jul 10, 2015 | 07:30 AM
DO IT ON ALL FOURS
Hey, if you trust that shady looking website then more power to you. You didn't say you were from another country; here in the states they are double the cost IF you don't pay full price for OEM. You can see they are $26.06 each in the link I provided above. That doesn't include tax, shipping, or the handling fee from ordering with Majestic. I always heard that OEM parts were WAY more expensive in Europe, but maybe my memory deceives me.
Yes, the LMA upgrade is recommended regardless of your setup. OEM will always be preferred unless you are running MASSIVE cams, but you would hit the oil rails before you would run out of LMA compression anyways.
Old Jul 10, 2015 | 08:01 AM
Oh right well i did read on here that oem costs more so i got arp head bolts without even looking at oem. They turned out to be more expensive then the honda ones haha, believe they are stronger though
What site are you reffering to as dodgey looking?
Cheers for dealing with my confusion and clearing things up
Old Jul 10, 2015 | 11:05 AM
DO IT ON ALL FOURS
ARP head studs are MUCH stronger than stock. There is no question there.
Jap Service Parts.
You are welcome.
Old Jul 10, 2015 | 11:08 AM
Nah they're good my friend knows the owner too.
Old Jul 10, 2015 | 11:41 AM
2kdrift's Avatar
ARP head studs are more expensive, but they are "better" especially for boost you will want them to prevent your head from lifting. Another benefit is they are re-usable unlike OEM so if you ever need to remove the head for any reason they will instantly become cheaper then OEM, I think they are a good investment. And yes they are definitely stronger very necessary for any boosted motor,
Neckbeard
19
Nov 8, 2018 03:53 AM
raverx3m
Aug 6, 2012 07:39 PM
ej93
Oct 26, 2010 12:26 AM
95teilhatch
Apr 10, 2007 04:23 PM
AutoXsi2000
Jan 16, 2005 07:40 PM
