how to separate tranny from the motor
Old May 12, 2016 | 11:39 AM
Type 56's Avatar
Default how to separate tranny from the motor
i've just recently got done removing the motor along with the tranny from the chassis. now my question is that how do i separate tranny from the motor. i took a few pictures from the recent work to show you guys what i'm working with atm.
As you can see here the engine and tranny is sittin' nice and soundly on a crate ready for separation.
the oil pan and everything else has been removed also to show what is left to work on with.
Old May 12, 2016 | 11:44 AM
BigBerz's Avatar
Default Re: how to separate tranny from the motor
Have your tried unbolting it from the motor?
Berz out.
Old May 12, 2016 | 01:42 PM
Aggression's Avatar
I think he's forgetting the bottom bolt for the starter, it goes all the way through.
Old May 12, 2016 | 08:19 PM
Type 56's Avatar
Berz out.
unbolting from motor? as in removing all the bolts that's holding motor and tranny together? if that's the case then the answer is "yes".
no, that bolt has been removed also already. i got another question for ya. what do you normally use to separate those 2 parts with once all the bolts has been removed? do you use a rubber mallet or something more hard hitting like a hammer?
Old May 13, 2016 | 06:56 PM
cruizinmax's Avatar
No hammer necessary. A pry bar at the most.
Old May 13, 2016 | 08:28 PM
Type 56's Avatar
so no hammer just a pry bar will do then huh. what about the crankshaft? can i still pry the damn thing apart while the crankshaft is still inside the motor?
Old May 14, 2016 | 07:06 AM
scottcraft's Avatar
10 Year Member
Loved
Community Favorite
Yes, you can pry it apart with the crankshaft in the motor.
Old May 15, 2016 | 07:14 PM
Type 56's Avatar
i finally got the damn off from the motor . the clutch and flywheel is next! thanks for the tip peeps
Old May 16, 2016 | 09:00 PM
crazes's Avatar
Moderator
take the mid shaft out of the tranny. You're causing unnecessary stress on the bearing right there. It slides right out.
tesw0n
Acura TL, RL & ZDX
Jan 2, 2019 12:32 PM
da9leo
Jun 26, 2007 08:18 PM
Mike17
Aug 8, 2004 10:34 AM
guttedsilvercrx
Jun 1, 2004 01:48 PM
