Head resurfacing
Old Jan 10, 2020 | 11:56 AM
purposebuilt's Avatar
Default Head resurfacing
I was woundering how many compression points dose. .020 of milling achieve. And how much is safe to mill a gsr head on a stock b20 bottom end. I'm only trying to achieve a 11-11.5:1 on a b20 vtec with a gsr head wit a 2 layer head gasket. So how much would I mill the gsr head
Old Jan 10, 2020 | 12:02 PM
Aradin's Avatar
Premium Member
Default Re: Head resurfacing
https://zealautowerks.com/bseries.html
Old Jan 10, 2020 | 09:14 PM
JRCivic1's Avatar
10 Year Member
Community Builder
Active Streak: 60 Days
Milling the head is a really bad idea. You get a bump in compression, but it is hard to tension the timing belt AND you increase the chances of valve to piston contact. The bottom line is if you want more compression, put pistons in it.
Old Jan 20, 2020 | 06:29 AM
416Gang's Avatar
Get some oversized Nippon B16 P30 or ITR pistons and get the compression you want.
boostedb20ek
Nov 9, 2010 03:46 AM
hYbRid_Eg6
Dec 20, 2009 07:01 PM
NoSwapNoCare
Mar 23, 2005 09:01 AM
allmotorbeasteg6
Aug 25, 2004 12:19 PM
jeremy.
Jul 13, 2003 08:31 AM
