Cylinder Head!!
Old May 21, 2020 | 01:41 PM
LatinoGang's Avatar
Default Cylinder Head!!
So just found out my cylinder head is bad. Question is should I resurface it or replace it?
Old May 23, 2020 | 08:30 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: Cylinder Head!!
Bad as in bent valves and combustion chamber damaged ??
Old May 26, 2020 | 05:15 PM
LatinoGang's Avatar
It’s not getting enough compression in one of the valves
Old May 26, 2020 | 07:37 PM
TomCat39's Avatar
Hysterically Calm
10 Year Member
Loved
Community Favorite
It all depends on why you have low compression in one of your cylinders. If it's a cracked head, that would be a replace. If it's a burnt valve then it's head work. If it's a bad head gasket, then you might not need anything more than a head gasket.
Until things are checked out, there isn't a way to answer your question accurately.
Old May 26, 2020 | 07:40 PM
LatinoGang's Avatar
i need to get it check ASAP with a good and and reliable mechanic that is certified for Honda..
Old May 31, 2020 | 03:06 PM
LatinoGang's Avatar
it’s a burnt valve so I have to get it done.
Malt-liquor
Engine Machining & Assembly
Oct 19, 2019 10:34 PM
soundquest
Sep 29, 2017 08:52 AM
deascendent
Apr 3, 2004 08:39 AM
