crank issue, thread damaged
Old Aug 2, 2015 | 10:59 PM
philcivicjordan's Avatar
Default crank issue, thread damaged
No idea how it happened (probably transportation) but i have a bent bolt in my crank, me and a friend managed to get it out hoping it was just the bolt that was damaged. Some if the threads are damaged hoping to re tap it on the same thread.
Having some trouble working out the pitch so if anyone has that on the top of their head would be helpful
Also any other options other then replacing the crank. Just rebuilt the engine then spotted this..such a set back for me right now arrgh
Old Aug 3, 2015 | 01:15 PM
Runnerdown's Avatar
Default Re: crank issue, thread damaged
Rule # 1, always list basics. The engine, and specific bolt (cr pulley, flywheel?) are 100% necessary to help you.
Old Aug 3, 2015 | 02:27 PM
Sorry i should of done that really its a b16a2 and its one of the flywheel bolts
Old Aug 3, 2015 | 02:51 PM
civic men's Avatar
it will depend on how bad and how much the thread are damage, you carry one of the good bolt your using just to match the thread. if the thread whole is rally bad just replace the fly wheel and bolt
Old Aug 3, 2015 | 06:18 PM
m4xwellmurd3r's Avatar
You can't replace the flywheel to fix damaged crank threads. If ts really gnarled and messed up you might need to find another crank
Old Aug 3, 2015 | 10:13 PM
Yeah theres no issue with the fly wheel.
Its not too bad, the first few threads have been effected.
Im just looking for a list of options. Other then the crank. Comes to that the car can stay off the road while i save for forged stuff.
First one is tapping the same thread in. Then hope. The thread isnt to mangled so it could work.
Or going for a larger pitch.
Another idea i had is to remove any loose bits. Taper the bolts slightly at the end and see if the thread can match up to the good threads further down
Old Aug 4, 2015 | 03:35 AM
If its only the first few but is clean further in you might be OK chasing the threads back to the same pitch. Just be careful and I'm sure using something like wd40 to lubricate the tap would help. But wait for more expert opinions before you do as I've never had an issue like yours
Old Aug 4, 2015 | 11:53 AM
the_unknown's Avatar
GDD Lonely Krew
Its not recommended but MANY people have run with more than one bolt missing out of their flywheel. Not saying you should do this just saying. If its only the first few threads, chase with tap, and try the bolt, if it torques fine then you're ok, or you could try to find a slightly longer bolt. Pictures would help a ton as everyones perceptions and estimations are different..
Old Aug 6, 2015 | 11:47 AM
KevinEF7's Avatar
There is over 20mm of threads, just re-tap it and carry on with the build
fastdohc
Jul 27, 2010 07:14 PM
Jamez
Mar 16, 2004 08:11 PM
youngkow
Nov 22, 2002 01:21 AM
baonest1
Nov 19, 2002 12:37 PM
BoostedED9
Jun 16, 2002 06:45 AM
