B20/Vtec engine torque specs
I am in the process of building a b20 with gsr head, it will be built for turbo with aftermarket internals. My question is which torque specs should I use gsr or B20 or Both? I try searching here on HT but was not able to find any posts specifying which torque specs to use.
This still is somewhat debated with ARP headstuds on B20/V builds:
https://honda-tech.com/all-motor-nat...0vtec-1676914/
So essentially, he recommends to torque (with ARP Lube) the cylinder head to about stock specs - 67 ft-lbs. This is because when you apply more load you risk distortion of the block / cylinders. Of course this is probably minimal, but really it's up to you. I will say I have been doing 67 ft-lbs for quite a few builds now (both N/A and F/I) and have had zero problems.
