B18c Eagle Rods in B18b?
Old Apr 2, 2019 | 10:40 PM
bldzrr's Avatar
Default B18c Eagle Rods in B18b?
So I bought a type r block and some eagle rods for it (b18c). I'm planning on building a bottom end for boost. Turns out one of the cylinders is messed up but a buddy of mine has a mint b18b block instead. Is it possible to use the b18c eagle rods in that ls block if I use the type r crank? Just to save me from finding another type r block or exchange the rods for ls. Is there anything else to note? Thanks, I'm new to this and will be my first time assembling a bottom end.
Old Apr 3, 2019 | 03:28 AM
KiNGDEE206's Avatar
Default Re: B18c Eagle Rods in B18b?
You can run the type r crank in the ls and then use gsr itr eagle rods yes
Old Apr 3, 2019 | 04:27 AM
motoxxxman's Avatar
or you can still use the type R block, and just go to an oversize piston. Then you don't have to worry about doing the normal vtec conversion when using a non-vtec block.
Besides; if you're building the motor you should be getting the cylinders bored/honed to match new pistons to make sure clearances are correct and the cylinder walls are fresh and new.
What exactly is damaged in the type r block?
Old Apr 3, 2019 | 08:03 AM
Chance EG's Avatar
Motoxxxman has the right idea. If you can bore out the ITR block .25mm, do it, and get the correct pistons for it.
Old Apr 3, 2019 | 12:07 PM
bldzrr's Avatar
Okay fair enough, I’ll get it bored out and honed. One of the oem pistons melted in it on the guy I bought it off of. There’s a bit of a bite out of the wall with some aluminum melted to it. Just enough to catch my finger nail on.
Old May 13, 2019 | 08:19 PM
BoostHatchFreak's Avatar
also the gsr block is a bit taller so you mite of had some piston to head issues if you did that with the ls block. I agree with everyone else bore the block you have already
jdmH2Bek4
Dec 22, 2012 01:14 PM
civic-r11
Apr 14, 2009 06:26 AM
beyondstock
Mar 8, 2009 12:41 AM
dayaftertomorrow
10
Apr 17, 2006 10:40 AM
7rrivera7
Feb 8, 2004 06:18 AM
