WTF is wrong here!?
Old Oct 5, 2007 | 07:24 PM
HondamanXxX's Avatar
GO GIANTS!
Default WTF is wrong here!?
Slip:
R/T....... .217
60'........ 2.488
330....... 6.884
1/8........ 10.446
MPH....... 65.87
1000...... 13.788
1/4......... 16.697
MPH........ 77.1
Modified by HondamanXxX at 8:46 PM 10/6/2007
Old Oct 5, 2007 | 07:28 PM
ShawnR's Avatar
Default Re: WTF is wrong here!? (HondamanXxX)
hahah mabey more seat time?
Old Oct 5, 2007 | 07:32 PM
GO GIANTS!
Default Re: WTF is wrong here!? (97gsrcoupe)
Modified by HondamanXxX at 8:47 PM 10/6/2007
Old Oct 5, 2007 | 08:11 PM
underpressure02's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondamanXxX &raquo;</TD></TR><TR><TD CLASS="quote">And a ******* short shifter or something. I'm ready to get the gun ready. I pull on my buddies WRX all the time and he runs 14.5. I think my problem is just being scared of breaking an axel or something. Plus, im not sure how to launch with this motor yet. Guess it takes time and not some stupid Falken tires.
But how does my car weigh so much. I was totallly shocked when I read it.
CF Hood
No back seats
No spair tire.
Car was empty!!! Nothing but front seats and a DOHC motor.
And how come theres no danm angry faces on Honda-Tech!!!$#!@$</TD></TR></TABLE>
EKs are heavier car in general. My 96 hatch weighs over 2500 with carbon fiber seats and no back seats. Just because you took out your spare tire and back seats does not mean your car will loose a ton of weight. That is prob 20lbs right there if that. The hood may save you 5 lbs or so. If you want to loose weight take out the sound deading material, lighter wheels, heater box and so on.
Old Oct 5, 2007 | 08:17 PM
paulzy's Avatar
sounds about right. they are rated at 2500 or something stock aren't they? Add teh extra weight of the DOHC and that's an extra 100 pounds.
Was that with or without you in the car?
missing 3rd sure explains the 77mph traps.
Old Oct 5, 2007 | 08:38 PM
japan4racing's Avatar
your short times suck *****. dont be scared to launch man. remember you will go faster spinning than you will trying to keep it from spinning. there is a big difference in traction and trying to make it hook through throttle modulation. once you loose the fear of breaking **** you will run faster. i used to have a turbo gsr vx civic. it went 13.8 and i was happy..but i was scared of breaking ****. a month later i went to the track and said expletive it..i launched harder and killed the car through the 1320...i ran 12.92 on street tires at nearly 117mph on 7psi from a 57 trim t3/t4 on a stock gsr. so you see. if you just get ovetr the fear of breaking **** and go ***** to the wall you will run faster.
Old Oct 5, 2007 | 08:51 PM
kermit97's Avatar
may be U dont know how to drive the car simple is that. quit complaining and learn how to drive the front wheel drive car thats all
Old Oct 5, 2007 | 09:09 PM
ATYPR's Avatar
looking at your MPH I'ld have to say your car is WAY down on power
Modified by ATYPR at 9:58 AM 10/6/2007
Old Oct 5, 2007 | 11:29 PM
hatchnideas's Avatar
Default Re: WTF is wrong here!? (underpressure02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underpressure02 &raquo;</TD></TR><TR><TD CLASS="quote">
EKs are heavier car in general. My 96 hatch weighs over 2500 with carbon fiber seats and no back seats. Just because you took out your spare tire and back seats does not mean your car will loose a ton of weight. That is prob 20lbs right there if that. The hood may save you 5 lbs or so. If you want to loose weight take out the sound deading material, lighter wheels, heater box and so on. </TD></TR></TABLE>
how does your hatch weigh so much? my 00 dx with full interior, half tank of fuel, and me in it weighs 2420...
and to the guy above a b18c is not an extra 100lbs, if i recall an h swap isnt even nearly that much more weight...
Old Oct 6, 2007 | 05:30 AM
93supercoupe's Avatar
Default Re: WTF is wrong here!? (hatchnideas)
EX and DX's have alot of differences, ABS power everything, sunroofs, ect.
Dont be scared to dump that bitch.
And the MPH was real low because he put it in 5th and not third.
Old Oct 6, 2007 | 05:48 AM
JDogg's Avatar
Default Re: WTF is wrong here!? (93supercoupe)
i went 14.4 at 95 in my old 97 coupe with a pretty fn stock gsr swap
so i'd say something is deffinatly off
Old Oct 6, 2007 | 05:56 AM
FRernesto's Avatar
Some helpful hints....Launch at around 5000 slip the clutch and you will be fine. Fuel pressure around 45lbs and that should work for a good ET. I ran and exact set up last year bone stock and went 13.1 at 102mph on slicks....
Old Oct 6, 2007 | 07:53 AM
eddie_ek's Avatar
Default Re: (FRernesto)
get those 60ft to 1.9 at least and dont miss 3rd thats the middle of the track thats were the speed comes. MORE SEAT TIME
Old Oct 6, 2007 | 08:52 AM
Bailhatch's Avatar
Default Re: (eddie_ek)
wire them damn runners open and do it again...or even fix it properly if you want
Old Oct 6, 2007 | 09:21 AM
paulzy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FRernesto &raquo;</TD></TR><TR><TD CLASS="quote">Some helpful hints....Launch at around 5000 slip the clutch and you will be fine. Fuel pressure around 45lbs and that should work for a good ET. I ran and exact set up last year bone stock and went 13.1 at 102mph on slicks....</TD></TR></TABLE>
how did you manage a 102 mph trap with a stock motor and full weight ex coupe?
Old Oct 6, 2007 | 09:31 AM
FRernesto's Avatar
Default Re: (paulzy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paulzy &raquo;</TD></TR><TR><TD CLASS="quote">
how did you manage a 102 mph trap with a stock motor and full weight ex coupe?</TD></TR></TABLE>
Well I did it in an EG....How did i do it well 60ft was 1.89 rt was .075 rev limiter at 9800 with a bone stock gsr. Stock factory headers and stock factory IM...Was stolen from me not even 3 months after dropping the motor in..
Old Oct 6, 2007 | 09:48 AM
FRernesto's Avatar
Remember a 1/10 in the 60ft is about 2/10 in the 1/4 so do the math...
Old Oct 6, 2007 | 10:26 AM
GO GIANTS!
Thanks for your help guys. More seat time for me for sure. Just want to pick up some Autozone axels just incase.
Will go back next week for sure
Also will 225/50/15 Drag Radials fit my car? I know thats a little extreme but just wondering if it will fit without any modifications.
Old Oct 6, 2007 | 10:55 AM
11SEC CIV's Avatar
Default Re: (HondamanXxX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondamanXxX &raquo;</TD></TR><TR><TD CLASS="quote">Also will 225/50/15 Drag Radials fit my car? I know thats a little extreme but just wondering if it will fit without any modifications.</TD></TR></TABLE>
they'll fit fine
Old Oct 6, 2007 | 12:20 PM
Mikey3000's Avatar
Remember a 1/10 in the 60ft is about 2/10 in the 1/4 so do the math...</TD></TR></TABLE>
that doesn't explain your mph though. how did you go 102 mph with a stock b18c in an eg. that don't make sense!
Old Oct 6, 2007 | 12:26 PM
FRernesto's Avatar
If you want I will post the time slips from the track. And you can figure it out all i know is that's what the car ran. The motor was purchased as stock motor and installed in the car...
Old Oct 6, 2007 | 10:21 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FRernesto &raquo;</TD></TR><TR><TD CLASS="quote">I ran and exact set up last year bone stock and went 13.1 at 102mph on slicks....</TD></TR></TABLE>
if that aint hooking i dont know what is!!!
Old Oct 6, 2007 | 11:07 PM
8herout's Avatar
Well I did it in an EG....How did i do it well 60ft was 1.89 rt was .075 rev limiter at 9800 with a bone stock gsr. Stock factory headers and stock factory IM...Was stolen from me not even 3 months after dropping the motor in.. </TD></TR></TABLE>
Duh, Because he was reving a bone stock gsr to 9800. LOL
Old Oct 7, 2007 | 05:52 AM
nsxmatt's Avatar
Default Re: (Mikey3000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mikey3000 &raquo;</TD></TR><TR><TD CLASS="quote">that doesn't explain your mph though. how did you go 102 mph with a stock b18c in an eg. that don't make sense!</TD></TR></TABLE>
I trapped 98 with a stock B16 in a hatch on DR's. It's possible although like mine it didn't trap that every run.
Old Oct 7, 2007 | 01:00 PM
Richard...'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondamanXxX &raquo;</TD></TR><TR><TD CLASS="quote">Slip:
R/T....... .217
60'........ 2.488
330....... 6.884
1/8........ 10.446
MPH....... 65.87
1000...... 13.788
1/4......... 16.697
MPH........ 77.1
Modified by HondamanXxX at 8:46 PM 10/6/2007</TD></TR></TABLE>
just curious what engine do you have DOHC what?
