Mfactory Straight cut gear set???
Old 01-10-2010, 03:48 PM
JBLAZE622's Avatar
Default Mfactory Straight cut gear set???
im looking into getting the Mfactory straight cut gear set that still uses syncros im getting tired of rebuilding stock trannys. I was just wondering if anybody else is using it? just looking for a lil more info on how it holds up my car makes 700+WHP any info will be great thanks
Old 01-10-2010, 04:04 PM
turbotypeR@SPEC's Avatar
Default Re: Mfactory Straight cut gear set???
I used it and it worked great! Steve Conley ran some 9.30's on them at 168mph and they are still working fine.
Old 01-10-2010, 04:14 PM
sanman000719's Avatar
is this the set that still uses your stock shafts you just replace everything with the MFACTORY set?
Old 01-10-2010, 05:09 PM
V-SPEC 1's Avatar
I believe so.
Old 01-10-2010, 05:13 PM
SWEET I WAS JUST LOOKING AT THIS THE OTHER DAY
Old 01-10-2010, 05:24 PM
Antilag's Avatar
Gears hold up just fine!! Went 2 seasons on them.
Old 01-10-2010, 05:33 PM
izzles01's Avatar
Gears HOLD up fine, We had them on Chads Hatch and that thing makes well over 850whp and it went 9.6x and were putting mine together as I type and I am looking to make well over 800whp....Pick it up...ASAP lol
Old 01-10-2010, 05:41 PM
REEMB18C1's Avatar
ques you guys running the mfactory str8 cut gears with syncro engagement are you guys using g force shifters and if so hows ur syncro teeths looking afta a few passin im lookin into a shifter but on a stock box at the moment just curious
Old 01-10-2010, 06:27 PM
izzles01's Avatar
I am using the g force shifter, but its yet to see track time, so much for my help lol
Old 01-10-2010, 07:08 PM
REEMB18C1's Avatar
iight thanks for the info any one else???????
Old 01-10-2010, 07:15 PM
Aquafina's Avatar
I've installed quite a few and none have had any problems.
No reason to use the G-Force shifter with the PRO Synchro gears as you still have to use the clutch. The 3/4 set works with the stock shafts. The 1/2 uses the MFactory mainshaft. Whether you use the 1/2, 3/4, or 1-4 you can still use stock 5th or a cuff.
Old 01-10-2010, 08:26 PM
I.C.C.'s Avatar
I plan on picking up the MFactory Pro Syncro set once I get my tax return... Heard nothing but great things about them, and the folks at MFactory seem to be very helpful, and customer oriented...
Old 01-10-2010, 08:54 PM
A train's Avatar
we love our sets they have never let us down just the damn bearings we keep killing! but we found out what that problem was! at least we are not grenading cases!
Old 01-11-2010, 03:58 AM
REEMB18C1's Avatar
cool only reason askin i hurt my motor on a misshift 2-3-2 last season not tryin to have it happen again im usin a stock tranny w/cuff the g force shifter is what im lookin into and that was my question for the guys running them with stock syncro engagement
Old 01-11-2010, 07:18 AM
4piston's Avatar
I have sold them to a couple customers making over 700 and they have had no issues. They love them.
Old 01-11-2010, 08:06 AM
locash's Avatar
If you're currently having synchro problems, thats not going to change. What's going to change is the life you get out of the gears themselves.
Old 01-11-2010, 09:08 AM
swapit's Avatar
i have 2 cars on the synchro set and havent had an issue yet both cars make 850whp+.I just ordered a 3rd set to have a back up for 1 of the cars.1 set we didnt get the input shaft and it has held up so for but havent hit it hard yet.The full set car has gone 9.53 at 163 and the car is going to P.R for the next couple of months to run the 3 races coming up there so they wanted a back up.
Old 01-11-2010, 06:04 PM
speeddave's Avatar
feel like sharing what solved the issue?
Old 01-11-2010, 07:09 PM
swapit's Avatar
We had 2 pinion bearings fail but our issue was no cuff was being used at first once the cuff was installed problem solved.
Old 01-11-2010, 07:53 PM
Aquafina's Avatar
Improper shimming, weak or used bearings. Cuff helps a lot but is not a necessity.
Old 01-23-2010, 09:40 PM
boostede46's Avatar
quick question, how long do the carbon moly synchros last on these gears?
Old 01-24-2010, 04:24 PM
A train's Avatar
not sure yet but we think its because we never ran a cuff! we will see soon!
Old 01-24-2010, 05:54 PM
JJsMotorsports's Avatar
pm me price of pro level gear set
Old 01-24-2010, 06:10 PM
The G force shifter has nothing to do with using the clutch or not. Most everybody using the G Force shifter uses the clutch anyway. I have used mine with syncro boxes and dogboxes. I would reccomend using the shifter no matter what tranny you use.
1320london
07-21-2014 02:14 AM
EgH22Turbo
Transmission & Drivetrain
03-22-2013 07:42 AM
Boostfed86
02-15-2013 06:46 AM
EDLOVA23
03-25-2011 01:13 PM
Quick Reply: Mfactory Straight cut gear set???
