Window Net Required For 10's???
Old Mar 13, 2003 | 10:31 AM
MotorMatrix.com's Avatar
I am a bad person
Default Window Net Required For 10's???
I was reading the rulebook last night and it states that you need a window net in the hot rod class. Is that assuming you will be runnins 9's?? my street car may not go 9's and I dont want to run a net if possible even though I'm in hot rod class. Anyone know if it mandatory no matter what time you run if you are in hotrod?? thanks
Old Mar 13, 2003 | 10:33 AM
DownOnPower's Avatar
Default Re: Window Net Required For 10's??? (MotorMatrix.com)
window net is required for a full cage
Old Mar 13, 2003 | 11:02 AM
I am a bad person
Default Re: Window Net Required For 10's??? (DownOnPower)
My street car has only a 6pt roll bar so i should be ok in the hotrod class w/o net right??
Old Mar 13, 2003 | 11:12 AM
GRTechnologies's Avatar
Interior:
Upholstery, headliners, carpets, etc. optional. If OEM dash is
removed, must be replaced with fabricated or aftermarket dash to
provide finished appearance. Must be equipped with one seat
minimum for driver, properly installed. Holes, slots, or other
openings in floor and/or firewall prohibited.
Window Net:
Mandatory.
Old Mar 13, 2003 | 11:20 AM
I am a bad person
Default Re: Window Net Required For 10's??? (GR)
I know but the general rules say only if roll cage is required. Maybe i should call.
Old Mar 13, 2003 | 11:28 AM
jinxproof99's Avatar
New User
if your talking about your street car, maybe you should throw in a oem tank and run the street class. thats what your car is better suited for and it wouldn't take that much effort. and your chances of winning anything might improve alittle.
Old Mar 13, 2003 | 11:32 AM
boostin b16's Avatar
Default Re: Window Net Required For 10's??? (jinxproof99)
i tghink you only need a window net if running over 150mph traps. after that i think you need a window net and parracute!
Old Mar 13, 2003 | 11:33 AM
I am a bad person
I know but I'm not really looking to be competitive in the street car. I'm just runnign for fun. It would take more than a gas tank to get me in that calss anyway. I have no headliner,stock dash or door panels,no exhaust,no oem streering column. I'd build a smaller lighter 92cx for that class and put my motor in it if i wanted to be competitive in street class. It woudl be less work too probably.
Old Mar 13, 2003 | 12:53 PM
littlebluecrx's Avatar
Mike, you do not need a window net for a 6 point, if you go over 135 or hit 9.99 you will need a full certified cage with a window net. So you might be on the brakes hard this year
Old Mar 13, 2003 | 12:56 PM
Default Re: Window Net Required For 10's??? (littlebluecrx)
what is the approximate cost of a full cage? what about a 6pt roll bar cost?
martini's Avatar
It's a class rule. which means that you will need it if you want to be in that class, no matter what times you are running.
You'll need a net AND a full cage.
Old Mar 13, 2003 | 01:01 PM
Default Re: Window Net Required For 10's??? (boostin b16)
It all really depends on what you want... Chromoly , mild steel? For it to totaly blend with you interior, or for it to be welded in then worry about making the interior fit. AFor a quote on a 6 point or full cage call Jeff from insane fabrications down in southern Md @ 301 855 0152
Jason
Old Mar 13, 2003 | 01:03 PM
I am a bad person
like the last guy said though. Its a class rule. think they enforce it?? No brakes for me jason. If i can go 9.99999@135+ I'll get kicked out with a smile
Old Mar 13, 2003 | 01:07 PM
Jason
thanx jason
Email Jim Skelly, he probaly wont get back to till next week, I know 2 years ago I was not allowed to run the hotrod class, because I had just a 6 point, my car was a mid 11 second car on the bottle back then. I ran brackets and had a good time anyways. I dont know if they make exceptions for cars that dont hit the e.t.'s that need a net or cage. Good luck...
Old Mar 13, 2003 | 07:50 PM
I am a bad person
I hope I dont get stuck in brackets. I really would like to run in a real class even though I'm going to just have some fun. I dont want to line up with an auto isuzu rodeo. I want a run for my money!!!!
92hondalude
Feb 20, 2013 06:44 PM
Mr Rex
Jul 31, 2006 06:07 AM
tom_l
21
May 10, 2004 04:22 AM
BsmoothR
Nov 25, 2003 07:02 PM
