Wideband
Old Sep 1, 2003 | 08:43 AM
dkdjlf's Avatar
Default Wideband
can someone explain what the 02 wideband is used for, difference? at the dyno.
Old Sep 1, 2003 | 08:52 AM
MackSpeed-616's Avatar
Default Re: Wideband (dkdjlf)
a wideband o2 is a good way to see what your actual air/fuel ratio is while tuning.
these sensors cost more and are much more acurrate than the stock piece.
they basically tell you if the car needs more or less fuel.
Old Sep 1, 2003 | 10:44 AM
civic disobedience's Avatar
Default Re: Wideband (MackSpeed-616)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MackSpeed-616 &raquo;</TD></TR><TR><TD CLASS="quote">a wideband o2 is a good way to see what your actual air/fuel ratio is while tuning.
they basically tell you if the car needs more or less fuel.</TD></TR></TABLE>
yep... only thing I will add to maybe help make it more clear is...
stock o2 sensors work on a 0V to 1V scale, the wideband works on a 0v to 5v scale much more acurate, and you need a special controler to run it, wont just plug into your stock harness, it has it's own black box that runs, and reads it...
Old Sep 1, 2003 | 12:05 PM
ghettoracer's Avatar
Banned
From: at last finally back to sweet home, sunny north cali, usa
http://www.g-speed.com/pbh/afr-o2.html
finest_GSR
Apr 28, 2006 12:53 PM
B16Civic93
Jun 24, 2005 08:40 AM
nickromeo
Feb 8, 2004 06:43 PM
importpower
Dec 25, 2003 06:21 PM
90teg
Jul 5, 2003 10:32 PM
