why would this happen?
Old Feb 6, 2005 | 07:51 PM
buzzbombtom's Avatar
Default why would this happen?
so i have a b16a2 with usdm itr pistons. that said i was at the track on wed night and on my third pass i blew up my motor, i was at about 8100 rpm when i shifted and it detenatoded (sp), we went and pulled the head off and found that ALL of my exhust valves bent just that nothing else was hurt by it. anyone know what might have happened? thanks
thomas
Old Feb 6, 2005 | 09:02 PM
93LSivic's Avatar
Default Re: why would this happen? (buzzbombtom)
Valve float from the sounds of it. Replace the springs with aftermarket ones and you will be ok
Old Feb 7, 2005 | 12:17 PM
NEXTAMERICANIDOL's Avatar
Maybe the timing belt was off a tooth?
Old Feb 7, 2005 | 12:27 PM
SSC1's Avatar
I agree, and if you missed a shift that will happen for sure with those pistons.
Old Feb 7, 2005 | 08:38 PM
Default Re: why would this happen? (SSC1)
why is that so, you say with thoes pistons its easy to misshift? how do those pistons make it easier to misshift. i didnt skip any teeth on my gears, unless i skipped them all because the belt and everything was at top dead center. dono thanks for all the imput
Old Feb 7, 2005 | 10:55 PM
jason DB8's Avatar
not having the pistons makes it easy to mis shift - he's stating that if you mis shifted and have those higher dome pistons it's easy to bend valves.
less margin of error with usdm itr pistons in a b16a2 than stock pistons is what he's saying.
i did the same thing at the track, went from third to fourth a little high in the rpms and dropped a couple of valves. that's racing
Old Feb 17, 2005 | 09:23 PM
ringerracer's Avatar
Default Re: why would this happen? (jason tC)
Old Feb 17, 2005 | 09:24 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jason tC &raquo;</TD></TR><TR><TD CLASS="quote"> that's racing </TD></TR></TABLE>
True That
white90crxhf
Dec 20, 2010 02:47 AM
ehansford22
Feb 18, 2010 06:57 PM
1xfastxhatch
16
Dec 20, 2008 09:22 AM
Andyman395
Jan 13, 2008 07:36 PM
H22CD7
May 2, 2007 11:26 AM
