wheel hop from hell!
Old May 1, 2006 | 12:08 AM
HYBRID_H@TCH's Avatar
Default wheel hop from hell!
ok we went to the track friday so I could finish tuning my car and all hell broke loose!
I was in the burnout box and brought the car up on launch limiter and began my burnout..all was fine till I started to roll out of the burnout and the front end started hopping BAD..I lifted as to not break anything but the car was hopping so hard I hit the gas again and took out the final drive..now I pretty much know what causes wheel hop but..I cant figure out why Iam getting this bad of hop..Iam setup as fallows..
L-Con traction bars
Omni power full coil overs
ES chassis master set
JimFab motor mounts
alignment has been check before the track and after
now with all I have done Iam still getting wheel hop that makes the front end of the car just hop..any ideas why this is so bad and what I should check? it seems this all started once I put in the twin disk..
Old May 1, 2006 | 05:19 PM
Default Re: wheel hop from hell! (HYBRID_H@TCH)
anybody?
Old May 1, 2006 | 07:08 PM
SFWD 1934's Avatar
David,
Do you use the Bogarts (Drag On Fly Star)? If so, check those suckers, make sure that nothing happened to them (i.e. bent rim) they are so soft that they can get a bend in them pretty easy. Also, check those slicks too if they are the ones that used last season. If you use the MT 26" they shake like a mother anyways.
Just a few things to look at.
Jason
Old May 1, 2006 | 07:22 PM
Jokerluv's Avatar
check the lug nuts ?
Old May 1, 2006 | 07:29 PM
tony1's Avatar
Default Re: (Jokerluv)
What tire pressure? Wheel screws?
Old May 1, 2006 | 08:03 PM
Default Re: (tony1)
Bogarts,straight as a arrow,25x8.7x13 M&H,9 psi to 5 psi same ****..
we just got everything apart and all looks good (well not the final drive! LOL) tires have even wear and all looks clean..Iam lost!
Old May 1, 2006 | 08:15 PM
tony1's Avatar
Maybe a blown shock or something, that is definitely not normal. Check all your suspension bushings too, something may be worn out.
Old May 1, 2006 | 08:31 PM
*Boostwerks*'s Avatar
From my experience I would have to point my finger at the L-con traction bars...but that might just be me...
If not that, then probubly a blown shock like tony said. I would push down on either side of the car, and see if it bounces or not.
Old May 1, 2006 | 08:36 PM
JDogg's Avatar
Default Re: (Bryson)
check those es bushings in the front, they tend to deform and wear pretty bad over time
Old May 1, 2006 | 08:58 PM
Hybrid_Coupe's Avatar
Default Re: (JDogg)
the bushings are pretty much brand new...we put them in less than a year ago...and he's on omni suspension that is a little over a year old... but we will definately check all that stuff out...i am also on l-con traction bars and i havent had any probs, but then again it was probably because i was still on a single plate clutch...however the same night david broke his tranny, i was in the right lane and got a little wheel hop coming out of the burnout box in the right lane just like him...
Old May 2, 2006 | 01:00 PM
Fitti's Avatar
Default Re: (Hybrid_Coupe)
what track were you guys at having all this trouble?
Old May 2, 2006 | 03:05 PM
Default Re: (Fitti)
LACR (palmdale)
Old May 2, 2006 | 03:11 PM
Boostfed's Avatar
New User
Stop playing with the switches, hydraulics are supposed to be bouncing and hopping y0!!!! Sorry no help from me
Old May 2, 2006 | 03:17 PM
h22 civic's Avatar
Default Re: (Boostfed.com)
no flat spots on the slicks
Old May 2, 2006 | 05:21 PM
Default Re: (h22 civic)
I had the hydro shop redo the switchs to the rear only just like you terry!! LOL..
slicks are damn near brand new and I just spun them on the car and everything looks fine..I was told I was under powering my burnout and thats the reason I was hopping..Iam going to try longer 1st gear burnouts instead of 2nd gear burnouts and see what it does..
Old May 2, 2006 | 05:46 PM
hondaguyef's Avatar
Default Re: (HYBRID_H@TCH)
I had the same problem with my old EF hatch. Even when on slicks it would wheel hop like crazy. It turned out to be the front shocks. Both were blown(passenger side worse than the driver side). I just never paid attn. until I blew a FD as well .
Monroe Heavy duties from Kragen did the trick
Phil
Old May 4, 2006 | 04:43 PM
Any updates on your car man?
Old May 4, 2006 | 05:03 PM
ATS*Mark's Avatar
OG triple OG
did u let your rpms get too low when you got out of the box? sometimes my car hops bad when the rpms get low.
Old May 4, 2006 | 06:31 PM
L-CON1's Avatar
Default Re: (Hella_JDM)
if all else fails try a softer spring!
deflection happens in a back and forth motion on these cars. with a solid bar there, it wont be able to move back and forth. the only thing that can be happening now is that your wheel is going up and down!from my experience when all else checks out to be ok its probably the springs.
hope i could have been of some help. good luck!
louie
Old May 6, 2006 | 12:12 AM
Default Re: (L-CON1)
well...
we went thru the car top to bottom and found nothing to be wrong..took the springs off the struts and all struts are good and all bushings are in great shape..I did a 1st gear burnout in the street infront of my house and it acted fine..but second gear hopped like crazy! and this was at a 9K rpm burnout on the limiter!!
Iam going to try some softer front springs (been told by sevral people this is most likely the issue) and see what it does.
Old May 6, 2006 | 04:54 AM
eddie_ek's Avatar
Last year I went to the track with my turbo EK on MT slics on take off my with the worst wheel hop I ever seen my darn radio came out hit me on the hand my spoiler broke off and broke both axles but I did a strong 15.3sec 2.4 60F sucks,I had honda shocks with yellow 2" drop springs I thought it was my cheap suspesion.I bought a Ti Force traction bar with the same cheap suspension and slicks I ran 12.6 at 111 1.78 60F wow what a diffrence I love my traction bar no wheel hop at all.
Old May 6, 2006 | 02:57 PM
Default Re: wheel hop from hell! (eddie_ek)
well after a interesting phone call I went out and started my car and put it in 1st gear (while on jack stands) and found this..
right click save as....
right tire. http://highboostracing.com/mis/tires1.avi
left tire. http://highboostracing.com/mis/tires2.avi
think this matbe a problem? that left tire is like egg shaped..also tires are at 10 psi in these clips.
Old May 6, 2006 | 11:23 PM
I think that would definetly be one possibility. I could see at a certain revolution that little out of roundness causing it to hop.
I've also known unbalanced wheels to cause wheel hop. I would talk to Mr M&H and see what he thinks.
Old May 13, 2006 | 03:32 PM
well..
I took my slicks over to the man himself and it turns out the tube in the driver side may have been bound up (kinked) and the pass side wheel may have a slight bend to it..will find out more monday.
Old May 13, 2006 | 05:53 PM
Dragline's Avatar
I don't know how well this would work on rims with slicks....but I don't see why it wouldn't.. You can go to A tire shop that has A Road Force balancer and have them spin them and it will tell you right were your problem is, weather it be in the tire or wheel and its exact location.
Here is A link http://www.hunter.com/pub/prod...x.htm
