what's the purpose for this switch
Old Jan 26, 2005 | 02:17 AM
RICE POLICE SIP's Avatar
Default what's the purpose for this switch
I kind of have an idea but are they necessary? http://moroso.com/catalog/cate...42225
Old Jan 26, 2005 | 03:36 AM
Clayton's Avatar
H-T Administrator
25 Year Member
Default Re: what's the purpose for this switch (Split Image Prez)
It's necessary if your battery is relocated away from the stock position, and you want to race at a sanctioned track.
Clayton
Old Jan 26, 2005 | 04:02 AM
XXXRacing's Avatar
Default Re: what's the purpose for this switch (Clayton)
it's also mandatory at certain ets/speeds. I believe 10.99 / 135 MPH.
Old Jan 26, 2005 | 05:21 AM
Savalicious's Avatar
the reason this switch is required is in case of a crash, the entire car can be shut off by the switch from the rear by the track resque team in case the driver is knocked out and the car is still running, which can be dangerous if gas and oil are spilling from the wreck. hope that explains it for ya.
Default Re: what's the purpose for this switch (XXXRacing)
If it is required for those speeds/times... Why? emergency purpose or? What if I don't relocate the battery, do I still need it even if I run those times/speeds?
Old Jan 26, 2005 | 06:45 AM
maxspeedhonda's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Split Image Prez &raquo;</TD></TR><TR><TD CLASS="quote">If it is required for those speeds/times... Why? emergency purpose or? What if I don't relocate the battery, do I still need it even if I run those times/speeds?</TD></TR></TABLE>
HHRA states that it is required in all vechicle running faster than 9.99 or in any vechicle with a battery mounted in a non-factory location. Like previously stated, it is for safety reasons. If you don't relocate your battery, you will need it if you run faster than 9.99.
Old Jan 26, 2005 | 07:26 AM
Default Re: what's the purpose for this switch (maxspeedhonda)
thanks...
philosofy1
11
Dec 8, 2007 09:33 PM
mrdeadman
Audio / Security / Video
Sep 23, 2006 08:52 AM
TegLover4life
Apr 29, 2003 12:47 PM
