What is a spool???
Old Dec 3, 2002 | 11:24 PM
allmotorhonda's Avatar
Default What is a spool???
what is it?
who makes them?
what does it do?
Old Dec 4, 2002 | 06:55 AM
UNDER PRESSURE's Avatar
Default Re: What is a spool??? (allmotorhonda)
1. Something spooling up.
2. My turbo.
3. Makes my car go faster.
[Modified by UNDER PRESSURE, 8:09 PM 12/4/2002]
Old Dec 4, 2002 | 08:15 AM
bigTom's Avatar
Default Re: What is a spool??? (UNDER PRESSURE)
its a solid diff essentially... with a stock diff... the wheels basically spin when they want... with an lsd... it locks the wheels in case one spins but during turns it will release one to make turning easier... a spool locks both wheels at all times... it is one solid piece... so when u make a turn... u are draging one wheel around in the turn
pro-drive, mark williams and a couple other companies make them... dss is in the process of makeing them
Old Dec 5, 2002 | 10:49 AM
highbrid's Avatar
Default Re: What is a spool??? (ek9t)
and they are a little harder to drive on the street...believe me
Old Dec 5, 2002 | 02:01 PM
boosted92's Avatar
what is it?
who makes them?
what does it do?
A spool is basically your rear end is locked at all times
Not a clue for hondas
Makes it really hard to turn, but you get a ton of grip, don't have to re-build it like an LSD, and no noisy gears like with a detroit locker.
Old Dec 5, 2002 | 02:05 PM
integRated109's Avatar
Default Re: What is a spool??? (boosted92)
makes U-turns in the rain quite tricky
Old Dec 8, 2002 | 11:34 AM
kidkutz's Avatar
Default Re: What is a spool??? (integRated109)
forget the spool...get a quaife...especially for a street car
Old Dec 8, 2002 | 04:07 PM
TREVER's Avatar
forget the rain makes U turns tricky period
Old Dec 8, 2002 | 04:39 PM
Norcalstoppy's Avatar
Default Re: What is a spool??? (TREVER)
so spool would be perfect for a rwd drift car?
would it help with handling at a road race or anything for hondas?
I can't imagine how a car would drive with the differential locked all the time. It's like having a solid bar from one wheel to the other.
Jay Kim
Old Dec 10, 2002 | 12:28 PM
Shant K's Avatar
Default Re: What is a spool??? (AllMotorMonster)
what about a welded diff? is that bad, can you weld a type R diff and or can you use a gsr diff in a itr tranny?
is a stock typr R lsd good for drag racing?
Old Dec 10, 2002 | 12:49 PM
TheOne's Avatar
Default Re: What is a spool??? (d-V-o-)
what about an lsd that makes kind of a grinding noise when i am going slow and turning, and is a little less noisy when I am going faster in a turn. just sounds really bad when I am at a stop and have to make a turn from the stop. Its a jdm b16 lsd supposedly.
Old Dec 11, 2002 | 09:31 AM
highbrid's Avatar
Default Re: What is a spool??? (TheOne)
the spool would not be good AT ALL for a road race in a honda. Unless the road race was in a straight line......
MackDad
Aug 24, 2006 06:22 PM
sslude
Mar 14, 2003 03:24 PM
comptechgsr
Mar 13, 2003 11:15 AM
jayRSX
Jan 21, 2003 07:00 AM
gcajnr21
Apr 3, 2002 11:39 PM
