what size rod?
Old Apr 29, 2003 | 10:38 PM
rocket_R's Avatar
Default what size rod?
is everyone using stock size rods or longer ones? how do you go about choosing what size rod to go with? i heard longer rod will help top end, but how do you know what size to go with without running into problems? looking for some for a h22 turbo.
Old Apr 29, 2003 | 10:48 PM
b19coupe's Avatar
Default Re: what size rod? (rocket_R)
Rods are a specific length and width for each engine. The only way to use a longer rod is to add a deckplate or use a crank with a shorter stroke, or modify the piston.
I think what you are looking for are just aftermarket H22 rods. Check Crower, Eagle, Pauter,Cunningham, etc. to see who makes a rod that fits your budget and your engine.
Old Apr 29, 2003 | 11:38 PM
MotorMatrix.com's Avatar
I am a bad person
Default Re: what size rod? (b19coupe)
what are you trying to accomplish with a custom rod?? going all motor, boost??
Old Apr 30, 2003 | 03:53 PM
QCKGSR's Avatar
Default Re: what size rod? (MotorMatrix.com)
use a longer rod to achieve a better rod ratio especially in those h22a
Old Apr 30, 2003 | 06:53 PM
I am a bad person
Default Re: what size rod? (QCKGSR)
yeah, ok we used a shelf piston and stock rod and made 689whp at only 26psi. if you hurt a rod do you really want to wait months to get your car back up and running?? run shelf parts and make the power with more boost!!
Old Apr 30, 2003 | 06:56 PM
ninesecrx's Avatar
or buy 6 of everything so you have spares if or when you hurt it so you wont have the down time.
Old May 1, 2003 | 06:41 AM
bambooluv's Avatar
stick with the factory spec'd rod. Hey if its good enough for kenny and tony than I think itll do good in your setup.
riceball777
Dec 3, 2005 02:25 PM
notoriousB
Jun 16, 2005 07:41 AM
racerboyb18c1
Nov 6, 2003 10:23 PM
ringgold
Apr 28, 2003 02:03 PM
gsrvx
Dec 15, 2001 11:27 AM
