what are the rules for having a fuel cell ????
Old Jan 11, 2008 | 09:46 AM
JBLAZE622's Avatar
Default what are the rules for having a fuel cell ????
i heard you need a fire wall between the cell and the driver are there any specs on how thick the wall is and what its made out of????
Old Jan 11, 2008 | 10:04 AM
T4eg's Avatar
Default Re: what are the rules for having a fuel cell ???? (JBLAZE622)
there are no rules as of right now bunjee cord it
Old Jan 11, 2008 | 10:50 AM
JBLAZE622's Avatar
so there is no rule of a fire wall or anything???
Old Jan 11, 2008 | 11:04 AM
4piston's Avatar
Default Re: (JBLAZE622)
Yes there are general NHRA rules for having a fuel cell. That is a safety rule and not a class rule, so that won't change.
http://www.nhrasportcompact.co...7.pdf
Old Jan 11, 2008 | 11:07 AM
NOPIDRAGS's Avatar
Tanks: When permitted by class regulations, fuel tanks located
outside body and/or frame must be enclosed in a steel tube frame
constructed of minimum 1 1/4-inch O.D. x .065-inch chrome moly
or .118-inch mild-steel tubing. All fuel tanks must be isolated from
the driver’s compartment by a firewall, completely sealed to
prevent any fuel from entering the driver’s compartment. All fuel
tanks must have a pressure cap and be vented outside of car
body. A positive-locking screw-on fuel-tank cap is mandatory on all
cars. Insulated fuel tanks prohibited. When used, fuel cells must
have a metal box protecting the part of the fuel cell that is outside
of body lines or trunk floor, excluding hose-connection area in rear.
Non-metallic fuel cells or tanks must be grounded to frame.
Top it off with a SFI 28.1 spec cell and you will have no problems as long as the class you run allows cells....
Old Jan 11, 2008 | 02:02 PM
JBLAZE622's Avatar
yea i'm not doing any competition pretty much a weekend car/racecar just something to have fun with but i'm running an external pump and braided lines so i was debating on a sumped tank or a cell but i think i'm just gonna do a sump thanks alot tho
thebonniesong
Feb 26, 2008 07:29 PM
TypeRobert
Sep 9, 2006 02:06 AM
digitalspice
Dec 18, 2001 07:57 AM
laughinxxx
Nov 14, 2001 10:25 AM
