What is the proper method for burnouts in the box?
Old Oct 28, 2003 | 09:18 AM
turbo83lude's Avatar
Default What is the proper method for burnouts in the box?
you all start in first? ever shift to second or third gear?
Old Oct 28, 2003 | 09:47 AM
highperboi's Avatar
Default Re: What is the proper method for burnouts in the box? (turbo83lude)
If you shifted your wheels would stop spinning for a little while and you would move forward out of the box.
Old Oct 28, 2003 | 10:42 AM
ykracing's Avatar
Default Re: What is the proper method for burnouts in the box? (highperboi)
i start in second, and stay in second... on 24.5 slicks
Old Oct 28, 2003 | 10:44 AM
ladysman's Avatar
Default Re: What is the proper method for burnouts in the box? (trboCIVICWRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by trboCIVICWRX &raquo;</TD></TR><TR><TD CLASS="quote">i start in second, and stay in second... on 24.5 slicks</TD></TR></TABLE>
Dropping the clutch in second?
Old Oct 28, 2003 | 10:57 AM
Kwuaymaikrup's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by highperboi &raquo;</TD></TR><TR><TD CLASS="quote">If you shifted your wheels would stop spinning for a little while and you would move forward out of the box.</TD></TR></TABLE>
Really? Go ahead and shift, just make it quick. You will be fine. As far as starting in 2nd....I always wondered that as well. If you have a good clutch I guess it would work.
-Ryan
Old Oct 28, 2003 | 11:02 AM
turbochic's Avatar
Default Re: What is the proper method for burnouts in the box? (Kwuaymaikrup)
i do a burnout in 2nd...rev to like 7k and drop the clutch...does a good burnout for me
i have 24 inch slicks
&lt;---just look at the pic...lol
Modified by turbochic at 12:17 PM 10/28/2003
Old Oct 28, 2003 | 11:05 AM
ykracing's Avatar
Default Re: What is the proper method for burnouts in the box? (ladysman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ladysman &raquo;</TD></TR><TR><TD CLASS="quote">
Dropping the clutch in second?</TD></TR></TABLE>
yup....
Old Oct 28, 2003 | 04:41 PM
ladysman's Avatar
yup.... </TD></TR></TABLE>
Sweet. Just what I thought.
Thanks turbochic. I have 24.5" slicks just haven't used them yet.
Old Oct 28, 2003 | 05:12 PM
12secB18acivic's Avatar
I start on 2nd and keep the rpm@7000 and let down the ebrake once I feel a little pull.
Old Oct 28, 2003 | 06:44 PM
smokey2.0's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kwuaymaikrup &raquo;</TD></TR><TR><TD CLASS="quote">
-Ryan</TD></TR></TABLE>
i tried both ways, on 15" azenis. i personally like dropping the clutch in second gear, trying to shift while doing a burnout takes some practice
Old Oct 28, 2003 | 11:54 PM
ringgold's Avatar
Default Re: What is the proper method for burnouts in the box? (smokey2.0)
I think that Im gonna try the 2nd gear burnout on my 22x8x15 MT's. Maybe this weekend?
Old Oct 29, 2003 | 07:07 AM
MaxBoost's Avatar
New User
Default Re: What is the proper method for burnouts in the box? (ringgold)
What about waterbox etiquette??
For FWD Cars, do you roll thru the water box and burnout right in front of it where it's semi moist, with the rear tires still in the box? and then roll out and stage??
Do you roll thru it completely and do a burnout in the dry? Do you burnout in the box?
Old Oct 29, 2003 | 07:11 AM
sircrxracer's Avatar
Default Re: What is the proper method for burnouts in the box? (MaxBoost)
I start in 2nd for sure, I go in the water and do a quick spin move forward till the edge of the water and drop it the when you fell it pulling you out of there drop the e-brake. Rob
Old Oct 31, 2003 | 07:13 AM
ykracing's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MaxBoost &raquo;</TD></TR><TR><TD CLASS="quote"> Do you burnout in the box?</TD></TR></TABLE>
NO! pull forward past the box... spinning in the water is a no-no...
Old Oct 31, 2003 | 07:22 AM
GRTechnologies's Avatar
i put mine on the 2 step and pull the staging brake and pop the clutch
Old Oct 31, 2003 | 07:04 PM
Default Re: (GRTechnologies)
thanks guys for all the responses.....atleast i know now what you guys are doing for burnouts..........i really need to get a two step though. It would make things so much easier.
Old Oct 31, 2003 | 09:46 PM
quik sol's Avatar
I can usually get into 4th in a burnout as long as theres a good amount of water in the box, but I only do that when I am doing burn-out contests, I usually just pop the clutch in first and do quik shifts to 3rd and let off the e brake and pull her forward...not really hard, I shift fast when going down the 1/4 just as fast as when doing burnouts...
Old Nov 1, 2003 | 06:45 PM
Mista Bone's Avatar
D Tranny Guru
proper burnout for FWD.......IF the water box is under control............
release the ebrake and let the rears roll through the water.....
ALWAYS 2nd gear, even on SOHC D15 power!!!!!!!
Old Nov 1, 2003 | 06:52 PM
GreenR's Avatar
Default Re: What is the proper method for burnouts in the box? (Mista Bone)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mista Bone &raquo;</TD></TR><TR><TD CLASS="quote">proper burnout for FWD.......IF the water box is under control............
ALWAYS 2nd gear, even on SOHC D15 power!!!!!!!</TD></TR></TABLE>
Only on slicks or maybe drag radials or else your burn up your clutch.
1st gear for street tires (stocks)
Old Nov 1, 2003 | 09:00 PM
crewchief's Avatar
Default Re: What is the proper method for burnouts in the box? (GreenR)
does second gearreally work.... im just curious
Old Nov 1, 2003 | 11:47 PM
Flamenco-T's Avatar
Default Re: What is the proper method for burnouts in the box? (crewchief)
On the race car, I usually lined up the front slicks right at the water, put it in 1st gear, chirp it for a slight second untill all surfaces are wet, then roll out of the water box at the moist area, then put it in 2nd gear, rev it to 7000 rpms ish (or use two step), dump the clutch and just keep flooring it. let it bounce off the rev limiter and turn the steering wheel side to side. Once you feel like you have gotten enough heat, release the e-brake and roll out.
Same thing on my street car..
stan
Old Nov 2, 2003 | 12:16 AM
Captn. Save A Hoe's Avatar
Default Re: What is the proper method for burnouts in the box? (Flamenco-T)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Flamenco-T &raquo;</TD></TR><TR><TD CLASS="quote">On the race car, I usually lined up the front slicks right at the water, put it in 1st gear, chirp it for a slight second untill all surfaces are wet, then roll out of the water box at the moist area, then put it in 2nd gear, rev it to 7000 rpms ish (or use two step), dump the clutch and just keep flooring it. let it bounce off the rev limiter and turn the steering wheel side to side. Once you feel like you have gotten enough heat, release the e-brake and roll out.
stan</TD></TR></TABLE>
Showoff
Old Nov 2, 2003 | 09:02 AM
Flamenco-T's Avatar
Default Re: What is the proper method for burnouts in the box? (The P.I.M.P)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The P.I.M.P &raquo;</TD></TR><TR><TD CLASS="quote">
Showoff </TD></TR></TABLE>
hahhahahahahahaha, you just know notice it ? LOL
stan
Old Nov 2, 2003 | 10:48 AM
ahahhaha...lol... yea i just noticed...
Old Nov 2, 2003 | 12:31 PM
AR Fab's Avatar
been playing with 26" and 28" with third gear....depending on track temp we may lower boost level a little bit....
Howard
