What et's should i be pulling??
Old Aug 29, 2004 | 09:40 AM
qwkcivic95's Avatar
New User
Default What et's should i be pulling??
Current set up is h22 w/ T-66 ball bearing turbo puts down 511whp@23psi. ran the car yesterday and went 11.1 @132 1.7 60ft on 24.5" slicks spinning pretty bad. car wieghs about 24-2500 w/ me in it. What et's should i see w/ bigger slicks and what would you recommend for slick size, i plan on bieng up over 600hp very soon.
Old Aug 29, 2004 | 03:08 PM
qwkcivic95's Avatar
New User
Default Re: What et's should i be pulling?? (qwkcivic95)
anyone??
Old Aug 30, 2004 | 12:09 PM
qwkcivic95's Avatar
New User
come on someone has to have an idea!!
Old Aug 30, 2004 | 03:33 PM
Gerhard_001's Avatar
should be running about mid tens
Old Aug 30, 2004 | 05:24 PM
86si's Avatar
Default Re: What et's should i be pulling?? (Gerhard_001)
you don't need bigger slicks,maybe some suspension work
Old Aug 30, 2004 | 05:37 PM
Phil DeVtec's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Gerhard_001 &raquo;</TD></TR><TR><TD CLASS="quote">should be running about mid tens</TD></TR></TABLE>
Old Aug 31, 2004 | 02:49 PM
qwkcivic95's Avatar
New User
Default Re: What et's should i be pulling?? (Phil DeVtec)
thanx for your response guys.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Phil DeVtec &raquo;</TD></TR><TR><TD CLASS="quote">
you don't need bigger slicks,maybe some suspension work </TD></TR></TABLE>
what would you recommend for rear suspension??
Old Aug 31, 2004 | 06:26 PM
86si's Avatar
900-1000lb springs,I am running 900's and they seem to be working well.
Old Aug 31, 2004 | 08:02 PM
AMS MIKE's Avatar
or 13's depends on driver.
I have an idea. run the car then tell everyone what you did. Nothing better than the facts
Old Aug 31, 2004 | 08:24 PM
SpoolnG2's Avatar
Default Re: What et's should i be pulling?? (AMS MIKE)
should run mid 10s with that mph. Thats a good 60ft too. Sounds to me like driving is the issue. Thats a good 60ft...good mph..but in between there something is taking to long. Maybe your shifiting? are you power shifting or just shifting regular?
Old Sep 1, 2004 | 07:53 AM
qwkcivic95's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AMS MIKE &raquo;</TD></TR><TR><TD CLASS="quote">
I have an idea. run the car then tell everyone what you did. Nothing better than the facts </TD></TR></TABLE>
check first post!!!
Old Sep 1, 2004 | 07:54 AM
qwkcivic95's Avatar
New User
Default Re: What et's should i be pulling?? (SpoolnG2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpoolnG2 &raquo;</TD></TR><TR><TD CLASS="quote">should run mid 10s with that mph. Thats a good 60ft too. Sounds to me like driving is the issue. Thats a good 60ft...good mph..but in between there something is taking to long. Maybe your shifiting? are you power shifting or just shifting regular? </TD></TR></TABLE>
i could probaly improve on my shifting, need some more seat time
Old Sep 2, 2004 | 07:07 AM
prelude9999's Avatar
I say 10 flat if you can get good traction.
Here is a good formula for 1/4 mile times:
5.825*(WEIGHT/WHP)^(1/3)
("WEIGHT" IS WITH DRIVER AND "WHP" IS WHEEL HORSEPOWER, NOT AT THE CRANK)
Old Sep 3, 2004 | 03:44 AM
SpoolnG2's Avatar
Default Re: What et's should i be pulling?? (prelude9999)
Hes allready getting pretty good traction. Atleast i think i 1.7 60ft is pretty damn good. What are u launching at? what is the pressure in your slicks at?
Old Sep 3, 2004 | 04:55 AM
86si's Avatar
1.7 60 is great,thats good for a low 10 sec pass
Old Sep 3, 2004 | 04:58 AM
SIXTYdashONE's Avatar
HT's Biggest Loser
Default Re: What et's should i be pulling?? (86si)
with that weight, and a 1.75 60ft time, you should see high 10's
with that weight and a 1.70 60ft, you should see maybe mid 10's..
Your trap (132) is good for high 10's@2500lbs..
whomever said 10 flat needs to go back to the domestic forum, hehe
BTW, what rpm, tire pressure and boost are you launching at. Do you have a dual stage boost controller? You need to give a little more info if you want help
Old Sep 3, 2004 | 05:34 AM
86si's Avatar
Default Re: What et's should i be pulling?? (SIXTYdashONE)
your gonna need better than a 1.7 60 in a domestic to go 10 flat.Lincoln Morehead(NHRA Super Stock)9.98 1.27 60.All down low
boosted k20
Feb 21, 2008 06:15 PM
DSRxPRESIDENT
Northern California (Sales)
16
Mar 21, 2007 01:32 AM
karter_2_22
Nov 28, 2005 10:29 PM
Turbo D' Sol
Apr 23, 2004 06:20 PM
Rescued R
Jul 30, 2003 05:58 PM
