What do you plan on doing in 2003?
Old Jan 20, 2003 | 09:47 AM
slowman's Avatar
I took way too long
Default What do you plan on doing in 2003?
Well I want to hear what all the drag racers have in store for '03. Performance wise.
Here's mine:
Turbo the D16A6(7 psi)
Completely new Fuel Injection system
FMIC
P&P
Falken Azenis
if i can get that done, i will be happy! i wanna hear what you all are gonna do
Old Jan 20, 2003 | 10:07 AM
theclutchpoppa's Avatar
Default Re: What do you plan on doing in 2003? (slowmanEF)
well i have a 88 crx SI that needs to be brought back to life
i have a a6 block with a z6 head ready to go in...i plan on adding the following this year..
New clutch either ACT,Exedy,or action
ZEX nitrous kit
ZDYNE one wire conversion
AEM CAI ,E/H
A set of good DR's or slicks
maybe a homemade turbo DSM style to replace the ZEX
and gut the hell out of the interior....
as you can tell im on a very limited budget but im dying to at least pull a mid 13 second pass hopefully ill be able to achieve it....then when winter hits im either gonna slap a b series in the CRX or buy a 1g DSM or turbo 2 RX7...i gotta come up im getting to old to have such a slow car
Old Jan 20, 2003 | 10:09 AM
slowman's Avatar
I took way too long
Default Re: What do you plan on doing in 2003? (theclutchpoppa)
Youll be able to get at least a mid 13 out of that setup!! Im on a limited budget too! that's why im throwing a junkyard turbo setup together. with a starion IC and DSM BOV. im hoping for low 14s/ high 13s. good luck!
[Modified by slowmanEF, 2:10 PM 1/20/2003]
Old Jan 20, 2003 | 10:39 AM
Civic_95_Si's Avatar
8.8 or better in the 1/8th. Turbo my lil D16 and see what happens.
Old Jan 20, 2003 | 04:25 PM
KGbabee's Avatar
Here's mine:
FMIC
P&P
Falken Azenis
shhh its a secret...no one should tell, just bust out and make everyone go WHOA!!!!
Old Jan 20, 2003 | 04:43 PM
boosted3g's Avatar
Default Re: What do you plan on doing in 2003? (KGbabee)
Finally get a 9 second run. i have been ******* around too long. I said screw it and tore 400 lbs out of the car and let the registration expire. I just want to race.
Old Jan 20, 2003 | 09:48 PM
ExospeedAMcrx's Avatar
Full Interior CRX.. no fiberglass at all. Low 12 second daily driven D16A6 all motor
[Modified by exospeedAMcrx, 6:48 AM 1/21/2003]
Old Jan 20, 2003 | 10:41 PM
THE GAME IS THICK's Avatar
Default Re: What do you plan on doing in 2003? (exospeedAMcrx)
I plan on droppin in a B20 with a GSR tranny and basic bolt-ons in my sol best thing for less than 2g's (if parts inquired correctly)
Old Jan 20, 2003 | 10:51 PM
ALLMTRWHORE's Avatar
having me a 10 sec. all motor car! by the summer! I'm threw f****** around!
Old Jan 21, 2003 | 01:03 AM
Jdm_Rice_Monster's Avatar
Default Re: What do you plan on doing in 2003? (ALLMTRWHORE)
Break 12s with my ls turbo crx. Then break 11s after i get a clutch, new tranny, hondata s200, tunning, fuel pump, bigger exhaust, injectors, and some head work.. either that or get a gsr and transfer all my goodies.
Old Jan 21, 2003 | 03:30 AM
civic disobedience's Avatar
Default Re: What do you plan on doing in 2003? (JdmRiceMonster)
I am getting the AEM EMS installed and tuned soon... hopefully by March/April, along with that I am going with 550cc injectors, 3 bar map, and raising boost to 12 psi, after that I really need to work on mys suspension setup, I am considering the eibach drag launch springs with koni yellows, but the spring rates on the Eibachs are not exactly what I want and the koni's will need to be revalved, so I will prolly just save up the $ and go with the Tiens... and I just have to have the FULL RACE manifold!! that is the most awesome manifold I have ever seen!!! It all depends on how much money I can make this year... I make good $ but have a ton of debt
Old Jan 21, 2003 | 08:05 AM
laughinxxx's Avatar
New User
Default Re: What do you plan on doing in 2003? (civic disobedience)
Hondata, piece together a single fogger set up to use off the line and use my current direct port set up as the second stage, Koni yellows, get tuned and go to the strip as often as possible.
Old Jan 21, 2003 | 08:19 AM
autoEXturbo's Avatar
paxton pump, bigger lines, 720cc or bigger injectors, built head and chipped ecu.
Old Jan 21, 2003 | 08:41 AM
hybrid901's Avatar
Default Re: What do you plan on doing in 2003? (autoEXturbo)
Switching to 24.5" slicks from my old 22". Upped the boost from 15psi to 22psi.
Hoping for 10.9
Then switching to a sleeved block after that.
Old Jan 21, 2003 | 11:08 AM
Civicdrgrcr's Avatar
From: WTF DC Racer No Way Turbo Washington., DC, USA
Default Re: What do you plan on doing in 2003? (hybrid901)
To Hit 10's 2nd/3rd time at the track. Pray that nothing breaks.
Old Jan 21, 2003 | 07:12 PM
Pelican's Avatar
Default Re: What do you plan on doing in 2003? (Civicdrgrcr)
Have to second that.
....and that implies finishing the car.
"I wanna be silly-fast"
Old Jan 21, 2003 | 07:48 PM
AussieK24's Avatar
Default Re: What do you plan on doing in 2003? (Pelican)
Run 12's on street tyres on a stock B16 with bolt on's.....
Old Jan 21, 2003 | 11:08 PM
bretx0r's Avatar
im thinkin about going DOHC. Definately hitting 12's or lower by the end of the year.
Old Jan 21, 2003 | 11:42 PM
DLB1994's Avatar
Default Re: What do you plan on doing in 2003? (bretx0r)
hopeing for 400whp with my new setup and if i that looking for low low 12's or high 11's
Old Jan 22, 2003 | 01:15 AM
mitsuman's Avatar
Default Re: What do you plan on doing in 2003? (DLB1994)
well its not much but,
short term goal=
*89 DX hatch fully gutted
Black or White paint (cant choose)
b16a1 5-speed
custom turbo kit
t3/t4 turbo
starion FMIC
*Vortech S-fmu
CTR cams
aem cam gears
street/strip clutch (brand undecided)
Hasport mounts
chipped ECU
2.5 inch custom madrel bent cat back exhaust
GSR front seats
rims & tires undecided
im hoping to hit 12's with this setup.
*what i have so far lol
Old Jan 22, 2003 | 07:14 PM
allmotor92civic's Avatar
Default Re: What do you plan on doing in 2003? (mitsuman)
hopfully hit 10s all motor, if i can afford to finish my motor
Old Jan 23, 2003 | 08:54 PM
b19coupe's Avatar
Hit 12's all motor by spring. Then 11's at IDRC in November. Hope I get a good tax refund!
Old Jan 26, 2003 | 07:36 PM
TREVER's Avatar
Default Re: What do you plan on doing in 2003? (b19coupe)
Here's was the goal I reached last year....
Ran 11's, 92 si full interior and ac with a 2.0 liter and a 100 shot.
My goal this year is to do the same without the ac and nos.
It was to run 10's with a turbo, but I had to be more realistic due to funds.
Old Jan 26, 2003 | 07:48 PM
paulzy's Avatar
Default Re: What do you plan on doing in 2003? (TREVER)
mid-low 10's and at least a 140mph or bust....well, the car should be finished first
Old Jan 26, 2003 | 08:29 PM
flip1199's Avatar
Default Re: What do you plan on doing in 2003? (1320development)
Well since it seems like i'm the only prelude guy here. I have a few goal...
1. Finish my custom turbo kit and install it myself
2. Make 250+hp on stock internals
3. 13.6 or better or trap at 103+ mph
