WELD WHEELS FITTING ISSUE!
Old Mar 29, 2010 | 10:51 AM
Pleiadi79's Avatar
Icon2 WELD WHEELS FITTING ISSUE!
Hello to everyboby,
i've bought a pair of 13 x 9 weld part#768-30915 and when i try to fit them they "touch" the caliper and seem a 5mm or more spacer is required.
Do someone have had this problem? Is it ever possible? How can i fix that?
Seems to me also the clearance between the suspension arm and the rim is to small, is this part# correct for an eg?
Is there on the marker a differen hub that fits without a spacer?
Thx for help!!!!!
Old Mar 29, 2010 | 10:54 AM
imanoobhaha's Avatar
HAPPY FEET
Default Re: WELD WHEELS FITTING ISSUE!
Just grind down the caliper, thats what i had to do.
Old Mar 29, 2010 | 10:57 AM
redboost10's Avatar
this is what i did too with my weld racelites
Old Mar 29, 2010 | 11:06 AM
Pleiadi79's Avatar
QUOTE=redboost10;42014267]this is what i did too with my weld racelites[/QUOTE]
I think if i grind down the caliper it will be destroied! i miss about 10 mm. If i'll do this the wheel will collide with the arm! Are both of you sure is the same
part# are we speaking?
thx
Old Mar 29, 2010 | 11:08 AM
fresh_manny21's Avatar
When I had these wheels I used a spacer
Old Mar 29, 2010 | 11:12 AM
Pleiadi79's Avatar
What spacer size?
Thx
Old Mar 29, 2010 | 11:14 AM
1992Si's Avatar
Take some washers, put them on the studs, put the wheel on and see how many washers it takes to clear the caliper. Then measure the stack of washers.
Old Mar 29, 2010 | 11:24 AM
Pleiadi79's Avatar
just thinking at this thx
Old Mar 29, 2010 | 11:38 AM
redboost10's Avatar
thx
ive been running mine like this for 5 years now
Old Mar 29, 2010 | 11:49 AM
Pleiadi79's Avatar
with spacer i suppose...
Thx
Old Mar 29, 2010 | 11:51 AM
FRernesto's Avatar
Run a spacer and issue is resolved!
Old Mar 29, 2010 | 11:53 AM
tepid1's Avatar
Get the right spacer. Don't use the washers. You get more stability with the spacer. I got mine off of Ebay.
Old Mar 29, 2010 | 12:16 PM
redboost10's Avatar
Thx
with no spacer. just shaved the caliper a bit. get the wheel spacers, easier and quicker. i am stubborn and didnt want to use spacers
Old Mar 29, 2010 | 12:25 PM
Pleiadi79's Avatar
OKOKOKOKOKOKOKOKOOK Going to get a spacer!!!!!
Old Mar 29, 2010 | 02:03 PM
jdm inc's Avatar
i used 1/4" spacers on mine. cleared just fine.
Old Mar 29, 2010 | 02:34 PM
og asr's Avatar
Summit has them...$20.00 for the pair......and you use 1/4" spacers...
Perfect fitment!
Old Mar 29, 2010 | 04:05 PM
hello1320's Avatar
summit spacers wont pass tech. i just had to grind the hell outta my caliper and mounting bracket. i run the 13x10s 4 inch backspace.
Old Mar 29, 2010 | 04:09 PM
85mmek9's Avatar
I grinded the caliper a little and used a 1/4 spacer. I believe they were mr. gasket. they worked just fine, $30 spacers
Old Mar 30, 2010 | 05:05 AM
dpetro1's Avatar
why?
Old Mar 30, 2010 | 08:00 AM
FRernesto's Avatar
I did the same exact thing and worked out perfect with the 1/4" spacer. Make sure you have extended lug nuts.
Old Mar 30, 2010 | 12:57 PM
Pleiadi79's Avatar
I'm going to buy spacers but i think if i grind the caliper it will going to broke.
i need 10mm spacers that is more than 1/4 tho have 3mm clearance between caliper.
I've placed 2 washers for a total thickiness of 6mm ad the wheel touches a little the caliper. I think Eu calipers are little different for US one that's why i need 10mm
00MRSi
Suspension & Brakes
Jan 14, 2009 07:20 AM
rip94delsol
Mar 10, 2007 10:58 AM
red civic standard
Jun 6, 2006 07:20 AM
MI4$DC5
Apr 23, 2006 06:38 PM
12 oz.
May 9, 2003 11:29 PM
