weight transfer during launch
Old Nov 11, 2002 | 11:25 AM
b00stedbyFastrax's Avatar
Default weight transfer during launch
guys how do i prevent the front of the car from lifting during hard launch. i have the rear as stiff as possible, but it still transfer weight to the rear wheels.
Old Nov 11, 2002 | 11:27 AM
redcxhatch's Avatar
Default Re: weight transfer during launch (BoostedbyFastrax)
wheelie bars, move everything to the front of the car
Old Nov 11, 2002 | 01:32 PM
martini's Avatar
so you have the rear stiff...how about your front?
wheelie bars are an option. And try to bias your weight distro to the front.
Old Nov 11, 2002 | 01:47 PM
hybridreams's Avatar
What do you have done to make the rear as stiff as possible?
Old Nov 11, 2002 | 01:55 PM
speedworks's Avatar
Default Re: weight transfer during launch (hybridreams)
put some adjustable shocks on the front and back. that will help a ton.
Old Nov 11, 2002 | 03:02 PM
Default Re: weight transfer during launch (speedworks)
i have the tanabe sustec pro coil-overs. rear at the stiffest setting (8) and the front at the softest level.
Old Nov 11, 2002 | 03:12 PM
n/m
what about a bushing kit?
[Modified by hybridreams, 7:12 PM 11/11/2002]
Old Nov 11, 2002 | 03:14 PM
nope. just replacment inserts on the engine mounts.
Old Nov 11, 2002 | 03:42 PM
give that a shot. should stiffen you up all the way around
Old Nov 11, 2002 | 05:42 PM
Redline130's Avatar
what about using stiffer springs in the rear, like Skunk2 or Eibach ERS drag springs.
Old Nov 11, 2002 | 09:07 PM
tonydatyga's Avatar
or shallow stage, early launch and spread out the weight transfer over a slightly longer period of time. More clutch slippage at less than wot throttle. Make sure you're getting a good contact patch up front. Under power, not at curb height. Extreme positive can "help" the front come up just a smidge
Old Nov 25, 2002 | 04:45 PM
Jared's Avatar
the front shouldnt be soft, it allows it to rise up.
Old Nov 25, 2002 | 04:49 PM
speedworks's Avatar
Default Re: weight transfer during launch (Jared)
jareds exactly right. set the shocks on the front at there stiffest setting also
Old Nov 25, 2002 | 08:28 PM
ProTreeCRX's Avatar
fill up the rear with bumpstops
Old Nov 26, 2002 | 04:05 AM
Mista Bone's Avatar
D Tranny Guru
Default Re: weight transfer during launch (MnC CRX)
so I should get rid for my 150k+ mile shocks?
Damn 11's might no be so hard after all (note the humor!)
immajackuup
Nov 4, 2009 05:33 PM
StockEm2
Suspension & Brakes
19
Aug 31, 2009 06:58 PM
bazda
Dec 17, 2007 10:33 AM
J28S
14
Sep 25, 2005 08:40 PM
2fknlo
Mar 7, 2002 03:32 AM
