type r cams
Old Nov 17, 2010 | 06:26 AM
hello1320's Avatar
Default type r cams
Does anyone have the cam specs to degree these cams... open @ what crank degrees?? All I can find is the lift and duration
hello1320's Avatar
Default Re: type r cams
There.98 integra type r cams
Old Nov 17, 2010 | 07:06 AM
d16z6Tcrx's Avatar
set them @ 0,0
Old Nov 17, 2010 | 07:44 AM
hello1320's Avatar
If someone has this info it would be greatly appreciated
Old Nov 17, 2010 | 08:46 AM
tepid1's Avatar
Get a cam degree wheel and some dial indicators and figure it out.
Better yet, get a kit from Xenocron and call it a day.
Old Nov 17, 2010 | 09:10 AM
hello1320's Avatar
I have a kit. All the cams I've don't have had the specs I need.. how do u degree the cams of u don't know what crank degree the cam should be fully open.
Old Nov 17, 2010 | 09:53 AM
tepid1's Avatar
I think I understand what you are saying now....
PM sheepey. He may have that info.
Have you looked at http://www.webcamshafts.com/ under "Degree in your cams"?
Old Nov 17, 2010 | 10:29 AM
hello1320's Avatar
Everything I've read to find lca has been for symmetrical lobes.....just found the asymmetric method
Old Nov 17, 2010 | 02:02 PM
xenocron's Avatar
You dont, but you CAN note where lobe centerline occurs while building the motor and at least if you can find the specs later on (they must be somewhere) you can then adjust the cam gears based on the information you wrote down and measured
MrParks's Avatar
from what i understood the centerline on oem cams are 110? which is dead on with an oem cam gear or ge cam gear. the rest to me are all off on markings.
Old Nov 17, 2010 | 03:17 PM
hello1320's Avatar
I noticed that peak lift was not "in the middle of the measured duration" so I was kinda lost without a FL number
Old Oct 4, 2012 | 07:07 PM
dellas's Avatar
I would like this information too, it can be useful info for certain rough calculations?
Old Oct 4, 2012 | 08:14 PM
hello1320's Avatar
Lol.... Wtf was I thinking
Old Oct 5, 2012 | 12:16 AM
tepid1's Avatar
Hahaha
Spectators.... seesh
Old Oct 5, 2012 | 05:37 AM
Will_H's Avatar
Not sure if this will help.......
Intake opens at 10 degrees before TDC, closes at 40 degrees before BDC.
Exhaust opens at 40 degrees before BDC, closes at 7 degrees after TDC.
as for the center lines of the intake and exhaust cams ...take the total number of degrees separating the opening and closing, divide by 2. Add this number to the opening and you have lobe center.....
ek4serge
Mar 21, 2011 01:32 PM
threehonda
K Series
Dec 20, 2009 06:37 PM
ferio 95
19
Jan 29, 2005 12:09 PM
foma2.2
May 21, 2004 10:46 AM
86CRXSi
Jun 10, 2002 06:13 PM
