Trunk Battery Relocation in Hatch
Old Apr 10, 2006 | 09:51 PM
PinkMaggit's Avatar
Default Trunk Battery Relocation in Hatch
Just wondering what rules are they about putting the battery in the trunk instead.
does it have to be an enclosed box because it is in a hatchback?
Can be mounted anywhere? does it require specific Mounting?
Old Apr 11, 2006 | 08:18 AM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Trunk Battery Relocation in Hatch (PinkMaggit)
it has to be mounted in a box with an external vent. (if the box is inside the drivers compartment w/o a bulkhead) and if it is remotely mounted, there needs to be a master cutoff switch. i dont have my rule book in fromt of me, but i will look when i get home and quote it for you.
Old Apr 11, 2006 | 11:42 AM
PinkMaggit's Avatar
Default Re: Trunk Battery Relocation in Hatch (boostedcivicsir)
thanks. we are trying to mount it in the very back of the hatch. maybe right above where the spare goes.
Old Apr 12, 2006 | 05:47 AM
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">it has to be mounted in a box with an external vent. </TD></TR></TABLE>
even if it's dry cell?
Old Apr 12, 2006 | 09:11 AM
B20C1T's Avatar
yeah even if its a dry cell you still have to have a vent tube run out of the car. also the master kill switch must be at the rear of the car (rear bumper, tail light etc...). there is a wiring diagram of how to wire the master kill switch somewhere on here....i think.
Old Apr 12, 2006 | 09:52 AM
Mr. Badwrench
Default Re: (B20C1T)
and it must be clearly labled "OFF"
Old Apr 12, 2006 | 08:18 PM
B20C1T's Avatar
Default Re: (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir &raquo;</TD></TR><TR><TD CLASS="quote">and it must be clearly labled "OFF"</TD></TR></TABLE>
oh yeah thanks for adding that.
Old Apr 12, 2006 | 08:50 PM
2point2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B20C1T &raquo;</TD></TR><TR><TD CLASS="quote">yeah even if its a dry cell you still have to have a vent tube run out of the car. </TD></TR></TABLE>
that's gay.
Old Apr 12, 2006 | 09:24 PM
PinkMaggit's Avatar
Default Re: (2point2)
What guidlines or what set of rules is this coming from. Class etc.
Is there any guidelines for just running at the track unclassed?
Old Apr 13, 2006 | 07:22 AM
DRIVENRacing's Avatar
most of the rules are ******* gay
Old Apr 13, 2006 | 07:50 AM
Mr. Badwrench
Default Re: (adSPEED)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adSPEED &raquo;</TD></TR><TR><TD CLASS="quote">most of the rules are ******* gay</TD></TR></TABLE>
i will agree with that to some degree. they are there for a reason. i think drag racing is one of the safest firms of motorsports because of the rules. although i am hating my neck guard. tried it on for the first time.
Old Apr 13, 2006 | 03:03 PM
PinkMaggit's Avatar
NHRA rule 8.1 Battery must be firmly and securly mounted to the frame of the vehicle.
Anybody have an answer to this. Can I mount it somewhere other then the Frame or does it have to be on the frame?
Old Apr 14, 2006 | 06:59 AM
PinkMaggit's Avatar
Default Re: (PinkMaggit)
8.1
Old Apr 14, 2006 | 08:49 AM
B20C1T's Avatar
well if you are putting it in a honda hatch, you don't have a frame, you have a unibody car. which means the floor, the firewall, the trunk are all part of the frame. what i did with my relocation, is mount is where the spare tire used to be, i then made a hole off to the side and vented the line out side of the car. it was pretty simple.
Old Apr 14, 2006 | 09:21 AM
DC4_MADMAN's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PinkMaggit &raquo;</TD></TR><TR><TD CLASS="quote">What guidlines or what set of rules is this coming from. Class etc.
Is there any guidelines for just running at the track unclassed?</TD></TR></TABLE>
Its an NHRA rule and any track that follows NHRA rules wont let you run unless it is setup correctly- sealed box, vented to atmoshere with battery and alt kill switch mounted on rear of car. I know, I was denied running cause my kill switch only killed the battery and this was just a street legal fun at the track day, wasnt fun for me.
Old Apr 15, 2006 | 03:43 AM
Maldito X's Avatar
^^^^^ that's messed up, but if you leave it under the hood there's no biggie right?
Old Apr 15, 2006 | 08:36 PM
ATS*Mark's Avatar
OG triple OG
Default Re: (sLcREX)
heres mine , maybe it will give you mounting ideas
Old Apr 16, 2006 | 11:53 AM
crazy sohc vtec guy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adSPEED &raquo;</TD></TR><TR><TD CLASS="quote">most of the rules are ******* gay</TD></TR></TABLE> ya they are
Old Apr 17, 2006 | 08:23 AM
SiKnezzALLmotor's Avatar
Default Re: (gsrinacivic)
werd
Old Apr 20, 2006 | 10:18 AM
PinkMaggit's Avatar
Default Re: (SiKnezzALLmotor)
thanks for the pic. is there any restrictions as to whether or not nitrous can be right next to the battery?
Old Apr 20, 2006 | 12:01 PM
Mr. Badwrench
not that i am aware of, but again, it must have an external vent out of the drivers compartment.
Old Jul 21, 2006 | 02:22 PM
Kelly.'s Avatar
I've quit using this account
anyone have an example of a "external vent" ?
or would a tube running from the box through the floor surfice?
sorry if its a newb question, im just not sure how to "vent" a battery
sorry to bump a old thread, but atleast im searching
Modified by Kelly. at 4:42 PM 7/21/2006
Old Jul 21, 2006 | 02:55 PM
tony1's Avatar
Default Re: (Kelly.)
The battery has to be in a sealed box. The "vent" connects the inside of the box to the outside of the car.
Old Jul 22, 2006 | 09:00 AM
redboost10's Avatar
Default Re: (tony1)
you only need a battery kill switch if the battery is relocated, right? if its left in the stock location, nothing is needed?
Old Jul 22, 2006 | 09:20 AM
Kelly.'s Avatar
Default Re: (tgh99si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgh99si &raquo;</TD></TR><TR><TD CLASS="quote">you only need a battery kill switch if the battery is relocated, right? if its left in the stock location, nothing is needed?</TD></TR></TABLE>
a kill switch is needed even when it is in the stock location if you trap 135 or faster, or go 9.99 or quicker
