Tripping the lights
Old Mar 28, 2005 | 01:33 AM
SEFIxCivic's Avatar
Default Tripping the lights
At the track sometimes i see people with body work or exhausts that hang really low. is it possible for that stuff to hang so low that they activate the the prestage lights? if that happens how does it affect quarter mile times?
Old Mar 28, 2005 | 04:42 AM
Paul_VR6's Avatar
Default Re: Tripping the lights (SEFIxCivic)
Yes and yes. It's almost funny when the car hooks stupid hard and you get a 2.2 60'
Old Mar 28, 2005 | 04:51 AM
1 2 NV's Avatar
Default Re: Tripping the lights (Paul_VR6)
i agree with paul. my header was tripping the lights cause it hung too low. this resulted in lots of redlights and then when the car would lift the front end on launch i would end up with horrible 60's also.
Old Mar 28, 2005 | 08:12 AM
DIRep972's Avatar
Smarter than you
Yah, i've tripped the beams w/ my front end before. It makes virtually no difference in the 1/4 mile but it does make a difference in the 60' time. Basically it makes it a 63' time instead of 60' time, so you go slower in the 60' but by the 1/4 that 3' makes no difference.
Old Mar 28, 2005 | 02:07 PM
Garcia-Racing's Avatar
It does make a difference on the top end. Whatever you add on to you 60' you add on to your ET. 0.42 this weekend in Az. for me.
Old Mar 28, 2005 | 02:10 PM
DIRep972's Avatar
Smarter than you
Default Re: (Garcia-Racing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Garcia-Racing &raquo;</TD></TR><TR><TD CLASS="quote">It does make a difference on the top end. Whatever you add on to you 60' you add on to your ET. 0.42 this weekend in Az. for me.</TD></TR></TABLE>
No, not really. 3 ft. effects ur 60' time by 5%. 3 ft. only effects your 1320' time by .2%.. Not enough to make .42 difference something else must have happened to you.
Old Mar 28, 2005 | 02:20 PM
Trust me, I went over the time slips several times. 60' to 330' all the same - the difference of the 60'. All the was changed was raising the car up 2" so I was staging with my tire instead of the tip of the front end.
Old Mar 28, 2005 | 02:46 PM
hollandallmotor's Avatar
you are suppose to have 3" clearence from the ground to any part on car
Old Mar 28, 2005 | 08:44 PM
1 2 NV's Avatar
Default Re: (hollandallmotor)
not true cloyse, i believe its 3" from teh front of the car to 12" behind the front centerline of the axle then 2" thereafter. section 16 4.5 "ground clearance" f the 05' NHRA rulebook
93CamaroLT1
Mar 27, 2006 05:08 AM
EVLTEK
Dec 4, 2005 06:11 PM
Tippyman
Dec 4, 2005 04:11 PM
Kawaii
May 23, 2005 06:08 PM
jdmR
Nov 20, 2001 02:55 PM
